Help! 6.0 wont start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-24-2013, 08:10 AM Thread Starter
I have a 2004 late model (ipr on valve cover) I was driving down the road and the truck cut off with no warning and will not start back up. I put my scan tool on it ( Auto Enginuity) and didnt pull any codes. The check gauges light is on and the oil pressure doesnt move while cranking. I do get oil coming up to the oil filter housing when pushing on the valve with a screwdriver. The ICP pressure will reach 500 psi on a long crank but takes it about 20 seconds to get there and the IPR is about 84%. Im pretty sure i have a leak but arent sure if its a lpop or hpop issue. With a long crank it wants to start it gets to about 200rpm but will not and i get the smell of fuel out of the exhaust. At this point im stuck and no sure which way to go so any help would be appreciated.
jessehendricks is offline
post #2 of 6 Old 05-24-2013, 08:13 AM
ADMIN AND TECH
SCUFFY828's Avatar
if its filling the oil filter housing , shouldnt be the low pressure pump, ipr being at that high a percentage can mean a leak , what codes are in the pcm , start with that
ITS STOCK
SCUFFY828 is offline
post #3 of 6 Old 05-24-2013, 08:25 AM Thread Starter
the only code i did have was icp pressure low i cant remember the code i shouldnt have cleared it i guess
post #4 of 6 Old 05-24-2013, 11:14 AM
ADMIN AND TECH
SCUFFY828's Avatar
it definitly can help, 2285 can lead you toward a icp sensor , 2290 alot of times more toward the ipr and 2291 most of the time more towards a leak
if you dont have the code , id say next step would be to get a high pressure oil system test done to try and pinpoint a leak
ITS STOCK
post #5 of 6 Old 05-24-2013, 12:02 PM Thread Starter
thanks ill take a look at the icp this evening now that im more confident that im looking at a high pressure problem and not a low
post #6 of 6 Old 05-24-2013, 01:25 PM Thread Starter
checked the icp with no luck i am building 500 psi with a long crank but at 85% i thought the motor would still fire if i was building 500psi??
