I am back after installing new turbo - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-23-2013, 08:30 PM Thread Starter
I have a E series van.I wrote awhile back i had no turbo boost.I pulled the turbo and took it apart.The unison ring wouldn't move and everything was rusty or wouldn't move.Before I replaced the the turbo I was getting 2262 code.I replaced the turbo and hooked up my scan tool and am now getting the 2262 code as well as a 2263 code.I cleared the codes and took van out for a drive.if i put it to the floor I get a lot of blue smoke,missing and just won't go.I back off the throttle and engine seems to run better and smoke goes away and smooths out.I went through the manuals and I am reading it could be a ICP sensor.I do know when I had the scan tool hooked up I would get 1.3 volts at open throttle and was told I should have 5 volts.So I need some serious help here.I have a OTC geyinsys 3.0 scan tool.Will this tell me what the sensors are doing .Any other Ideas?
6.0Busman is offline
post #2 of 4 Old 05-23-2013, 11:49 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
If your only getting 1.3v at wot you either have a weak/failing pump or a pretty bad hpo leak.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 4 Old 05-24-2013, 09:11 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
From a previous post, you have more issues....
P2263 Code, and high EGTsI just had the same problem couple days ago. Once the cold hit my truck lost power and my boost was between 30-40 just driving normally. I changed the map sensor, the ebp sensor and tube. I probably could have cleaned them all but for peace of mind I just change everything. After I did that I cleared the code and truck runs better than before.
You may need to do some extra cleaning and checking. This could be the related to the low ICP voltage you are seeing. It would be very prudent to ensure the EBP sensor and tube are clear and working properly, as well as the MAP AND MAF sensors, especially given the level of corrosion and sticking in the old turbo. As well, ensure your VGT solenoid is working correctly. Of course, you could've have multiple issues as Tuscany suggested.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 4 Old 05-25-2013, 06:19 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
What year is the van? If it's an 04 you may have a failing high pressure pump that isn't allowing enough ICP to be built, I'd be looking at this last though, rule out the other things first. Plugged MAP port, plugged EBP tube or sensor, failing VGT solenoid.
You may also have an EGR valve that is carboned up or failed internally which would explain the smoke that clears up after you back off.
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
