Gaskets or cooler? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-23-2013, 07:43 PM Thread Starter
Gaskets or cooler?
I have an 06 F250 KR getting ready to turn over 130k. A few weeks ago I noticed the antifreeze was low. Added antifreeze and noticed it seemed to be leaking from around the cap. Bought a new one from advanced and thought I had the problem fixed. Coolant temps nor Oil temps ever went over 200 and stayed with 7-8degrees of each other. Well today I was pulling a car trailer with my Camaro on it, and she decided to heat up on me. Almost like a thermostat was sticking. Shot up to around 230 twice and pulled over and cooled down. Oil temps stayed consistent with the coolant temps. Unloaded the car at its destination and went home, the truck never heated up the whole 50 miles but ran temps slightly above 200. Upon arrival I found the degas bottle to be empty with no sign of it leaking. The truck seems to run fine. I quickly pressurized the system and it seemed to hold good pressure. No white smoke or anything. Just losing antifreeze somewhere. I am going to check it out tomorrow and see what I can find. I know this topic has been beat to death, but I have read and read and still not found the exact situation lol. Any help is appreciated. Thanks
2000-F-350-SUPERDUTY is offline
post #2 of 8 Old 05-23-2013, 08:06 PM
spoonfedblue's Avatar
Good luck! I'm planning to replace my oil cooler and delete the EGR this weekend. Then I'm going to cross my fingers and pray it's not the head gaskets. I'm kind of in the same boat, pulled a big load, after that my deltas went crazy. No smoke for me either, AND I'm not losing any coolant. I've marked the bottle and it's always right in the same spot. Get your hands on a pressure tester and out it on the degas bottle. Fire the truck up cold and watch for the pressure to build. If it get's up there pretty fast, it's probably head gaskets. That's what the diesel tech at the Ford dealer told me.
ASE Certified Master Tech A1-A9
L1 Advanced Level Specialist
yours
2006 F-250 SCSB 6.0 FX4 Lariat
285/70R17 Nitto Trail Grapplers, Upfitters w/ High Idle, 4" Turbo Back Straight Pipe, AFE 6" Polished Tip, Insight CTS w/ EGT, Blue Spring, IPR Gen 2, CAT ELC, DieselSite Coolant Filter, Cloud Rider Cold Front
spoonfedblue is offline
post #3 of 8 Old 05-24-2013, 09:23 AM Thread Starter
Yea it sucks. This is my only vehicle also and dont have time for down time. Im going to check into it a little more in a bit (try the bulletproof diesel thing with the bubbles). After a short bit of WOT earlier I had antifeeze puking from the bottle. Probably about 1/2 gallon after 5 minutes of hard running.
About how long does it take to change head gaskets on one, Im decent with a wrench. My guess is 12-14 hrs is a safe guess to be back up and running.
Thanks
post #4 of 8 Old 05-24-2013, 09:37 AM
rdaffin's Avatar
The labor time is close but the time the heads need to spend at a machine shop that is knowledgeable about 6.0 heads will be awhile. I would strongly recommend you get them checked. If not you could be looking at doing it again.
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #5 of 8 Old 05-25-2013, 03:58 PM Thread Starter
Does anyone know where to get a good write up on changing the head gaskets, and one for the EGR delete? Im not sure what is wrong with mine yet but would like to review the how-to's.
Thanks
post #6 of 8 Old 05-26-2013, 11:08 PM
Wobbly is offline
post #7 of 8 Old 07-01-2013, 06:48 AM
OkieTXHick's Avatar
just read this thread and was wondering if there were any updates on your issue? sounds a lot like my 04.
2004 F250 6.0L Crew Cab Long Bed 4x4 Auto
EGR Delete
Head Studs
4" Exhaust
Coolant Filter Set-up
OkieTXHick is offline
post #8 of 8 Old 07-01-2013, 07:18 PM Thread Starter
Yep head gaskets. She is fixed the right way with studs an all now.
