Turbo issue or egr - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-23-2013, 11:43 AM Thread Starter
Ak-Amarillo's Avatar
Turbo issue or egr
I have a 06 and it's been throwing a 299 and 470 402 coeds then I went to drive my truck it fired right up idel fine gave it throttle and wouldn't run past 1500rpm and filled my yard with gray smoke was told I had a stuck turbo so pulled it off the ring was stuck I put my brothers turbo that had low miles and in great shape on the truck ran good for 2 the. Starts to do same thing if its highway crussing low boost and rpm it acts up and sputters if I'm in the throttle it's fine it threw the same coeds again I know the turbo on it now is a good turbo would a stuck egr valve or faulty valve couase this I'm at a loss
Ak-Amarillo is offline
post #2 of 11 Old 05-23-2013, 12:07 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
Puncuation and spell check please!!!!
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #3 of 11 Old 05-23-2013, 12:10 PM
Term3's Avatar
Quoted: 2 Post(s)
So you wasted the time responding to a post just because you want someone to post with proper grammar and spelling. That's a GREAT help. P.S. you need to check your spelling also bud.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 11 Old 05-23-2013, 12:11 PM
Term3's Avatar
Quoted: 2 Post(s)
Yes, I'd pull the EGR valve to see if its coked up and sticking or not able to close fully.
Term3 is offline
post #5 of 11 Old 05-23-2013, 12:26 PM
Quoted: 275 Post(s)
Yes, I know I wasted my time. We'll call it lashing out at one too many run on sentences. I didn't think it looked right, but that's what I get for relying on spell check
post #6 of 11 Old 05-23-2013, 01:00 PM Thread Starter
Sorry I did it on my phone in a hurry. I pulled the egr valve it was clean and seemed to function fine. But since I've owned the truck I've had the excessive egr valve code. Witch is the 402 if I remember so my thought was its a bad valve coausing the turbo to suit up and stick.
post #7 of 11 Old 05-23-2013, 02:30 PM
Term3's Avatar
Quoted: 2 Post(s)
There is an updated EGR valve version I believe with a stronger return spring.
Term3 is offline
post #8 of 11 Old 05-23-2013, 02:33 PM
Term3's Avatar
Quoted: 2 Post(s)
LOL I hear yah. I've also read posts where I have to read it like five times to get what the person is trying to say. Heck even when I look at a post I just wrote I think what the heck is my brain doing and what does this iPhone think my brain is doing.
Term3 is offline
post #9 of 11 Old 05-23-2013, 03:21 PM
Quoted: 275 Post(s)
Thats exactly where I was coming from. Jus so happens this poor guy got my frustration venting. I do everything on this fandangod witchcraft I-pad and turned that stupid auto correct off, for these reasons.
post #10 of 11 Old 05-23-2013, 03:26 PM
Quoted: 275 Post(s)
And to the OP, after checking your EGR, if you find thats where the problem lies, clean it or replace it and then drive that truck like you stole it, at all times. Babying em to conserve fuel ends up costing more money by causing coked up egr's and seized unison rings. Even the dealership will tell you not to baby it. Good luck
