6.0 broken rod and busted block - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-23-2013, 10:43 AM Thread Starter
Thought my head gaskets blew. Took motor apart and found broken rod and busted block. It hydro locked on fuel. Any ideas on what happened? Have pics but do not know how to upload them
Snor0357 is offline
post #2 of 4 Old 05-23-2013, 11:32 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
If you are sure it was fuel, it's likely an injector that failed causing the hydrolock and the block damage. What are your plans now? Are you going to build a new 6.0 powerplant or swap in something different?
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 4 Old 06-09-2013, 09:37 AM
Texas Proud
charlie.thomas's Avatar
Don't feel bad, 3 months ago I cracked both heads and busted my block. I built a new one and love it, bored it .020" over and can feel the difference in towing.
"Feel the Fear and Do It Anyway"
2007 F250 King Ranch
Alligator Performance EGR Delete
5" AFE air intake
Blue Spring Mod
High Idle Mod
4" Turbo back straight exhaust
SCT Livewire TS tuned by the best, "Tony Wildman"
New block bored .020" over
New heads ported, polished, and decked
ARP Head studs
And other goodies
Lifted on 35" Toyo Open Country MT
charlie.thomas is offline
post #4 of 4 Old 06-13-2013, 06:27 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
It's pretty tough to hydroloc an engine with fuel when you are driving down the road. You should start blowing a massive amount of black smoke first. If it was from fuel you had to dump a huge amount in it very suddenly, probably a broken injector tip and/or injector cup. I've only seen three 6.0 core engines with broken rods in the past two years so it's pretty rare. Either way, I would definitely change all the injectors when you drop the new engine in. I can help you with everything you need if you give me a call.
AshevilleEngine.com is offline
