power loss at 2rpm/ made repairs now power loss at idle? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-23-2013, 11:23 AM Thread Starter
Thx for any help in advance.
2006 6.0 powerstroke 164,500 miles - no modifications, all factory
Sunday 5/19 pulling boat at about 55mph truck starts to stutter. I gas on it, blew black smoke (heavy) and check engine light comes on, got up to 60-65 and stutter goes and comes, go to 45 and stutters heavy. Monday, change undercarriage fuel filter and top motor fuel filter, during test found fuel pressure regulator leaking. Ordered from Ford house, replaced today and now truck in stuttering worse during idle, (which wasn't happening before), and stutters constantly unless I'm pushing over 2000rpm.? Turbo seems to be at proper pressure.
I do love my ford truck.
jumper1216 is offline
post #2 of 6 Old 05-23-2013, 11:28 AM Thread Starter
by the way, this is an awesome website, wish I would have found this years ago
post #3 of 6 Old 05-23-2013, 04:17 PM Thread Starter
I know no one has replied but I'm trying to give as much info as possible for anyone who can help. I did some more reading and decided to pull the EGR valve. It wasn't stuck but it was caked with black powder / same as an exhaust pipe, the orings were somewhat frayed, I wouldn't call it extreme. I didn't have that size orings so ill have to wait till tomorrow, but is the black powder I mentioned above normal or would the slightly damaged orings cause my problems or am I wishful thinking?
post #4 of 6 Old 05-23-2013, 09:03 PM
Tommyboy7777's Avatar
I believe im having the same issue,but its between 1800-2000rpm where the stuttering starts,then when I get on it it goes away and there is some smoke.......you have me wondering if the EGR valve needs to be pull and cleaned!
2006 CC XL Sport
6" Procomp lift
37" Kumho road venture MTKL 71's on 17" procomp 6001 series
4" MBRP stainless turbo back cat delete
Banks ram air intake and zoodad mod
Bulletproof EGR cooler
New OEM oil cooler
Rebuilt turbo
Sinister coolant filtration system
Dual steering stabilizer Skyjacker
skyjacker shocks all around
Edge insight CTS
6" in dash dvd
Delo CAT-EC1 coolant
Rotella T6 synthetic
motocraft filters
Tommyboy7777 is offline
post #5 of 6 Old 05-25-2013, 04:46 AM Thread Starter
OK, replaced orings on EGR. Broke down and purchased a code reader INNOVA 3150. Code from service engine light is P2290 injector control pressure to low. Can anyone give me some info on this?
post #6 of 6 Old 05-25-2013, 07:48 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
From reading the first post I would have said you had an injector or 2 with stiction issues or an FICM problem. This still will need checking as some problems mask or behave like other problems.
From your code, it is most likely a wiring/plug issue or you have a high pressure oil leak. I would recommend taking back the code reader and getting a good monitor (DashBoss, Scangauge II, or all-in-one programmer/monitor) or even an Auto-Enginuity with Ford bundle (diagnostic tool). The latter will help you the most if you plan on finding and fixing this yourself. You need to determine what your IPR is doing as well, but based on the code, the IPR is closing and the ICP is not rising to meet the demand. However, the IPR reading is not the actual position of the valve, it is the commanded position, so it will require more diagnosis to find the true problem.
Search out how to find a HPO leak. You will need to buy a M12x1.5 adapter to hook up shop air to help troubleshoot the HPO system.
FWIW, Today I put my Extreme tune back on my truck and when it was cold my HPO pressure would easily reach 4000psi. When I was driving down the road as it was warming up it was stuttering a bit at 1800 rpm until it warmed up. However, once warm the stuttering went away, but the max HPO I am now getting is 3000psi when warm. The power is also lower than expected. So it looks like I will have to track down a slight HPO leak and maybe a slightly off injector. I have no codes showing, so based on what is happening, I suspect it is related to a injector to rail seal, but it could be the standpipe and dummy plugs, the STC, IPR or even the HPOP. One thing to note is that with the stock or medium tune, the lower HPO does not show itself, making this probably harder to find. Since I will be doing some modifications soon (a different set of injectors (190/50), a turbo modification and perhaps the oil cooler (delta at 10*)), I will wait a while to rip into it, unless the pressure starts to drop. This is where the monitor will probably save me from being stranded or a road side repair.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
