Head stud alternate meathod? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-22-2013, 06:07 AM Thread Starter
would it be a completely terrible idea to just remove the TTY bolts and drop in the ARP head studs without pulling the heads and replacing the gasket?
2003 6.0 F250 "Onyx"
4inch lift
35'' Falken Wildpeak AT
SCT FX3 Performance tune
Edge Insight CTS
Edge EGT probe & Fuel Pressure sensor
Blue spring upgrade
Bulletproof Diesel EGR Cooler
Updated Motorcraft Oil Cooler
Sinister Diesel Coolant Filter
Rotella ELC
MBRP 4'' Turbo Back SS Straight pipe
Alpine head unit
Rockford Fosgate speakers
Still need to stud it....
aeby07 is offline
post #2 of 2 Old 05-22-2013, 06:55 AM
sprksonu's Avatar
search function in upper left corner will yield already talked about subject.
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
