Driving with stuck EGR valve. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-21-2013, 02:26 PM Thread Starter
Quoted: 4 Post(s)
My truck was in the shop today for a routine maintenance and as usual they hooked it up to the scanner to see if it had any codes. Well sure enough it was reading a bad EGR valve and the guy pulled it and the o-rings were worn and it was covered in soot to the point it was stuck open. Is it safe to drive my vehicle like this? My mechanic said it was but I wanted to double check with the fourms.
He did however unplug the valve.
Any thoughts?
Ps. I have a person lined up to install a delete kit but I'm trying to decide if I should do oil cooler as well.
joejack6.0 is offline
post #2 of 3 Old 05-21-2013, 05:40 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Any thoughts?
Clean it and replace the o-rings until you get the delete kit. I don't know that it's unsafe, bit it won't run right.
dhanna6powerstroke is offline
post #3 of 3 Old 05-21-2013, 05:50 PM Thread Starter
Quoted: 4 Post(s)
That's what they did. The o-rings aren't even for an EGR valve. They had to find a temporary fix as I'm getting the delete here in a couple
of weeks. Here are the kits I'm considering.
Black Diamond 6 0 Basic EGR Delete and Oil Cooler for 6 0 Powerstroke Diesel | eBay
and
Black Diamond Premium Solution Kit 6 0 Powerstroke EGR Delete Oil Cooler Gaskets | eBay
