Turbo bolt problem - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-21-2013, 09:16 AM Thread Starter
Turbo bolt problem
Hey guys. First thanks for the site. You have been a wealth of information. I have a 2005 Kingranch that I bought with 60K on the clock. It now has 95 and Im getting around to the EGR and oil cooler.
Got everything out on my way to the turbo but ran into a problem. First Ive heard of one of the bolts sometimes missing. My passenger side front bolt is. I got the rear bolt out on the first try and it was very easy. The drivers side front bolt however is a bear. It is not the normal 10mm like Ive seen on all the write-ups. Its much larger. Closer to 3/4. Cant get a shallow socket on it because of the intake. Is this an aftermarket turbo? It says Garret on the side. Any ideas why it doesn't have the normal 10mm bolts?
jeeptex is offline
post #2 of 4 Old 05-22-2013, 10:48 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
Best guess is the bolts were not replaced with the correct ones. There is a good chance the new larger head bolt is not metric and was forced in.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 4 Old 05-22-2013, 11:01 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
i hope that isn't the case but if it is.. get ALOT of PB blaster and try to get in there with an open end wrench
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #4 of 4 Old 05-22-2013, 04:32 PM Thread Starter
Got it out. 17mm. Used a 4in ratcheting wrench. Picked up three new 10mm. Don't know where it came from but it fit I guess. Got everything tore down but managed to strip one of the up pipe bolts changing it out for the new one that came with the kit. Oil cooler housing is clean just waiting to get back in.
Thanks for the help!!
jeeptex is offline
