Limp Mode - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-20-2013, 04:37 AM Thread Starter
Pistolgrip426's Avatar
Limp Mode
I had a bad coolant leak under the intake manifold,due to an inferior designed j tube,used for egr delete,the hold down let it wiggle around thus wearing out the o ring. anyhow ordered and installed a better billet pce. from Performance machine. leak fixed, replaced turbo and pedestal,and all the aftercooler piping and air cleaner assembly. truck fired right up,idles fine and no power ?, won't stall in gear,but won't move out of the shop,ran perfect into the shop,and actually has had no issues for month's, 04.5 6.0,f-550,4x4,auto trans,FICM 48.5-49 v while running, any ideas ? All I did was the turbo and pedestal removal,to access the j tube and the underside of the intake to re and re with new tube,and re-assemble,just a basic 4 hour job ,
2004.5 F-550,4x4,6.0,auto,CTS monitored,
Performance Machine egr delete,caterpillar elc,blue spring, CTS Monitor,flat plate agm batteries,K8 code, super tow pkg. (4.88),twin line recovery wrecker.
Pistolgrip426 is offline
post #2 of 3 Old 05-20-2013, 04:52 AM Thread Starter
also note,I have 2 brand new agm batteries,and she puts out 13.8 volts at idle,alternator is new,
post #3 of 3 Old 05-20-2013, 11:53 AM Thread Starter
Fixed problem, good to go
