No Start - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-19-2013, 05:24 PM Thread Starter
No Start
2006 6.0
While starting here are my Scan Gauge II values
IPR: 77.6
ICP: 183
FICM
-FMP:48.5
-FVP:10.5
-FLP:10.5
I tried unplugging the ICP, thinking it was bad and it still didn't start. Did I need to let it turn over for a while for this to work? I also checked the oil level to make sure it wasn't low. The IPR and screen was replaced a couple of months ago.
I'm thinking maybe one of my standpipe o-rings went bad or its the FICM.
Is there anything I am missing?
Macy is offline
post #2 of 8 Old 05-19-2013, 05:37 PM
spoonfedblue's Avatar
Somebody correct me if I'm wrong, but ICP needs to be at least 500psi while cranking. Sure seems like a high pressure oil leak to me. STC fitting?? There are air tests you can do on the HPO system. Search around, there's info on it here somewhere.
ASE Certified Master Tech A1-A9
L1 Advanced Level Specialist
yours
2006 F-250 SCSB 6.0 FX4 Lariat
285/70R17 Nitto Trail Grapplers, Upfitters w/ High Idle, 4" Turbo Back Straight Pipe, AFE 6" Polished Tip, Insight CTS w/ EGT, Blue Spring, IPR Gen 2, CAT ELC, DieselSite Coolant Filter, Cloud Rider Cold Front
spoonfedblue is offline
post #3 of 8 Old 05-19-2013, 07:21 PM Thread Starter
for got to add. replaced the stc filling when I replace the IPR.
Macy is offline
post #4 of 8 Old 05-22-2013, 08:08 PM Thread Starter
So, I let my truck sit overnight and tried to start it the next day. It started! here were my Scan Gauge values:
IPR: 77.6
ICP: 580
FICM
-FMP:48.5
-FVP:10.5
-FLP:10.5
Here is the kicker. when I put the truck in gear it stalled and then once it get up to operating temp it shut down. To me it sounds like a high pressure leak. I hope it is just one of the stand pipes. That's the only thing I haven't replaced on the truck.
Macy is offline
post #5 of 8 Old 05-22-2013, 08:27 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
High IPR and low ICP says HPO leak. I'd get your batteries load tested and alternator checked as well. 10.5v is way low. Good way to toast a FICM and injectors
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #6 of 8 Old 05-22-2013, 08:32 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1682 Post(s)
X2 What he said^^^
toren302 is online now
post #7 of 8 Old 05-22-2013, 08:40 PM Thread Starter
Yeah FICM readings look ow, but I think that's because I had been trying to crank it for a while. I should have mentioned that earlier. The batteries are brand new. Also both alternators are brand new too.
Macy is offline
post #8 of 8 Old 05-22-2013, 08:45 PM
Quoted: 275 Post(s)
Get those batteries charged back up before ruin em by discharging em
