Codes 0402 and 132P - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-19-2013, 01:03 PM Thread Starter
ColoradoDoug's Avatar
Codes 0402 and 132P
I have an '03 6.0 Excursion, stock. I do have a CTS Insight for monitoring purposes. I drove it yesterday (wife usually drives), and he seemed to stumble on occasion and I could hear the turbo flutter occasionally. Usually these happened around 1800-2000 rpm, part throttle, when steady or accelerating. Highway driving it was not noticeable. I looked at the CTS and found the two trouble codes (0402 and 132B).
After reading many posts on the subject, some say clean the EBP sensor and tube, but some say that on the '03, that the EBP is no longer read by the computer. I looked at the MAP sensor and hose and they were clean. While watching the gauges, when there was a stumble, the MAF reading would drop drastically, but very quickly and return to more normal (for what was shown) readings. Today I checked the VGT% and at idle it was 60-70+% and when I hit the accelerator, it would drop. I don't see or smell exhaust from the Y-pipe area. I do get EBP readings from the CTS. What can/should I look for on the CTS? and what figures? Lastly what else can I check myself? The EGR valve is not very old, it was replaced about 20K miles ago.
'03 Eddie Bauer 4x4 Excursion 6.0 Diesel, CCV mod, upgraded turbo drain, blue spring fpr kit, 6.4 banjo bolts, zoodad, v code front springs and modified b code rear springs, Bilsteins, Hellwig rear swaybar, '08 rear diff cover, 4x2 liftgate struts, 285 Michelin LTX A/T2's, tinted windows, DVD, XM, GPS
ColoradoDoug is offline
post #2 of 11 Old 05-19-2013, 03:06 PM Thread Starter
After another warm up and test drive, the MAP reading seemed correct. I'm at 5000' above sea level and I'm showing 12 psi and stayed consistent with the turbo boost. So at 3 psi boost the MAP was 15, etc. The MAF jump all over from single didits to a little over 100 g/s (?). When the engine would stumble or get sluggish, the MAF would drop quickly, and the VGT would rise to around 70-80%. After warm up, at idle, the VGT% was about 81%. Steady part throttle, the VGT was around 50%, until the issue arose then it would go to 70-80%. Could it be the VGT solenoid? Is there a way to test it? Should the MAF be all over the place? Again, just looking for clues and areas to focus.
post #3 of 11 Old 05-20-2013, 11:58 AM Thread Starter
Turned out to be the MAF sensor.
post #4 of 11 Old 05-21-2013, 09:15 AM Thread Starter
I feel like this is a one sided conversation here, but here is a little update.
This morning, the problem happened again, my MAF % was all over the place and the engine was running terrible. I took it back in thinking maybe it was a bad MAF sensor I got. The tech said he forgot to to the adaptive learning after replacing the sensor (disconnect the negative cable). He did that and took it for a drive and said it was good. I leave for home and 1/3 of the way home it starts acting up again. Not quite to the extent as before, but still running bad.
Still have a code 0402, but no longer have the 132B. Could it have been a bad MAF sensor or maybe something else?
post #5 of 11 Old 05-22-2013, 07:22 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
Sounds like you're gonna have to pull the EGR again for inspection and possibly a cleaning. Keep in mind, looking for anything other than soot in there ( gooey mess means bad egr). After that, take it out and beat the snot out of it, get those egt's up there to clean the cob webs out of it. I dont know how your wife drives, but if its her daily driver, she may not be runnin it hard enough. 6.0's need to be driven like their stolen, and taken out on the highway and opened up. City driving clogs em up
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #6 of 11 Old 07-29-2013, 02:30 PM Thread Starter
Still getting a stumble on occasion, but not all of the time. When it happens the MAF readings really jump around. Took it back to the shop and it won't replicate the stumble. So they couldn't fix what they couldn't find.
Fast forward to a week ago and I noticed this I am getting a oil spot under the engine. I just changed oil because it was time and cleaned things up to try and find the leak. But I also drove it around today and checked codes. I had;
p006A
p0341
p0401
p0402
p132B
I have the stock intake, not aftermarket. I have read that the EBP sensor is not read anymore??? So is it necessary to check the tube then? It seems to take a second before the turbo kicks in and then the power comes on. I have watched the VGT and it does show reading all over. How could I tell if the vanes are sticking? I also cleaned the EGR valve back in May or June when the problems started.
Ideas on where to start with this list???
Thanks
post #7 of 11 Old 07-30-2013, 06:47 PM Thread Starter
Anyone?
Sound like a defective MAF? Turbo that needs cleaned (what's a price range to get that done)? Something else maybe?
post #8 of 11 Old 08-05-2013, 04:42 PM Thread Starter
Anyone have any ideas?
post #9 of 11 Old 08-06-2013, 03:53 PM
Quoted: 275 Post(s)
If you PM me with an email I can send you a PDF which explains the P006A and P132B codes. The P0341 used to pop up on me ocassionally with no run issues. I finally felt it stumble one time, checked for codes and there it was again... Replaced the Cam sensor and inspected the harness. Code has yet to reappear. I dont want to tell you to throw money at it, but the EGR codes almost say that the EGR valve is faulty, sticking open or closed. There is a self test procedure to learn the closed position. Did you ever perform that procedure?
post #10 of 11 Old 08-08-2013, 12:36 PM
Quoted: 275 Post(s)
Email sent
