Black Smoke Help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-14-2013, 05:54 PM Thread Starter
Black Smoke Help
I need some help trying to figure out whats going on here...
I noticed my truck pouring black smoke from a stop sign acceleration. I know that may not seem bad, but its never done it before. There was no noticeable difference in power, just a ton of smoke. I had newer oil with about 1k miles on it, along with both fuel filters. I pulled the EGR valve and cleaned it and it didnt stop the smoke. I have an edge juice with attitude that I keep in stock about 99% of the time. It is showing no codes at all. Its also got a KN air intake, and magnaflo exhaust.
It only seems to smoke when the boost PSI gets up to 4-5 from a stop and then seems to fade off when I hit crusing speed. Im kinda leaning to either the turbo is going out or one or more injectors failing.... anyone have any ideas, thoughts or ways to tell which one it is? or am I way off?
Its a 2004, 6.0 with 169K
Thanks!
trujillo417 is offline
post #2 of 7 Old 05-14-2013, 06:05 PM
JayAF98's Avatar
You could pull your turbo and clean up the vanes. Sometimes sticking vanes or a sticking unison ring can cause it to not push enough air to clean it up. It's a cheap easy thing to try. While you have it if make sure it free spins and the vgt actuator moves freely.
JayAF98 is offline
post #3 of 7 Old 05-14-2013, 07:25 PM Thread Starter
Hey, thanks its worth a shot. What do you clean the vanes with? Can you tell by just looking if they are clogged?
post #4 of 7 Old 05-14-2013, 07:30 PM Thread Starter
Also, I forgot to ad that when I was stopped at a light, the truck surged forward and the RPMs went up a bit and then settled back down.... not sure if its related or not...
post #5 of 7 Old 05-15-2013, 06:07 AM
dxusmc's Avatar
I just use 3M abrasive discs with a drill to clean mine off. then put a nice coat of anti-seize on there and slap her back together. As far as the jump in RPMs, not sure what caused that since you don't have any DTCs. I'm not saying its not related, but I can't say that it is either.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #6 of 7 Old 05-15-2013, 09:47 PM
JayAF98's Avatar
I used the same thing, you kind find a kit at Walmart that has the small scuff pads and bit. It's hard to say if it's related or not.
JayAF98 is offline
post #7 of 7 Old 05-15-2013, 09:50 PM
JayAF98's Avatar
You can't tell just by looking at it, it's all going to look like it's coated in soot. You can rotate the unison ring after you have it split open and vgt actuator out to see if it binds at all. Once you have it open that far you might as well clean it anyway.
JayAF98 is offline
