Extended Start and Loss of Power!?!?!?!? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-13-2013, 06:33 PM Thread Starter
Red face Extended Start and Loss of Power!?!?!?!?
Hello,
I am new to the Forum world and Hope to find some Help.
I have a Ford F-350 6.0L Diesel, and It has extended cranks and A loss of power.
So far I have Cleaned and lubercaited the turbo, Replaced the Sdandpipes and dummy plugs and the O-rings on the HPOP. I now have the following DTC!
P0069
P0198
P0470
P0671
I am curious I need to replace the Map Sensor, I Wondered If I need to replace the HPOP, or maybe the top O-rings on my Injectors? I am at a loss...It does not over heat, It takes forever to get it to climb or 60-65 and tops out there and the RPS stay around 2,500.
Any thoughts?
Thank You and God Bless!
TomTheToolman is offline
post #2 of 7 Old 05-14-2013, 07:07 PM Thread Starter
I just got another code pop up and now it's a crank no start deal... P2285
I suppose the HPOP has gone out...any clues before I spent a paycheck on that?
post #3 of 7 Old 05-15-2013, 08:44 AM
Slacker
Evil Eye's Avatar
Quoted: 196 Post(s)
Feedback Score: 4 reviews
Hi Tom,
Here are the codes you are getting and what those codes mean... You basically sound like you have several problems with the truck and since you just worked on the truck, it sounds like you still have some wiring disconnected.
P0069 MAP/Baro correlation
P0198 EOT high
P0470 EBP sensor
P0671 Cyl 1 glow plug error
P2285 Injector CNTRL Pressure Senser CKT
You don't say what year your truck is, but based on your replacing the standpipes and dummy plugs, it's somewhere between 2005 - 2007. The P2285 means there is a problem with the signals getting to/from the ICP sensor to the PCM. Double check that you didn't nick/disconnect the ICP sensor on the passenger side valve cover. You need 500 psi in order to fire the injectors and the ICP tells the PCM how much to open/close the Injector Pressure Regulator (IPR) on the HPOP. The HPOP's on the 05-07 trucks are VERY robust and rarely require replacement, so I would look elsewhere. Do you have a diagnostic scanner to monitor ICP and IPR duty cycle?
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 7 Old 05-15-2013, 02:53 PM Thread Starter
Red face Double checked all wireing
I double checked everything and just to let you know it is the old style hpop the 03-04.5...
not sure if that matters... any other ideas?
post #5 of 7 Old 05-15-2013, 04:51 PM
PHYRMN's Avatar
An 03-04 shouldnt have a EBT sensor code. It was taken out of the 03-04 ECM stategy a while back. Just to be clear, what year does it say is on the door sticker?
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #6 of 7 Old 05-26-2013, 02:20 PM Thread Starter
I have replaced my HPOP on my truck after it sat a little over a week. I ran beautifully! drove it on the freeway and took it to 90 mph's. I could tell it wanted more but I didn't want to over do it. I drove home and let the truck idle in the driveway while I get ready for a date. then when I came out, the truck had died!?! I sried to start it up agian but all it would do it crank with no start.
I checked the codes and got the following:
P0069
P0098
P0198
P0335
P0336
P0460
P0463
P0470
P0478
P0671
P2285
P2614
P2617
then I cleared the codes and tried starting agian and checked the codes and this is what I have now...
P0069
P0098
P0335
P0671
P2285
ANY THOUGHTS, PLEASE HELP!?!?!
post #7 of 7 Old 05-26-2013, 08:17 PM Thread Starter
Wink update
I have gotten the codes down to p0069, p0335, and p0671
I am still trying to figure this one out and need help!
And Yes its a 2005 Ford F-350 Crewcab 4X4
it has an egr delete, straight exaust from the turbo back and a tuner on it.
