help!? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 05-13-2013, 12:28 AM Thread Starter
06SiXOh's Avatar
help!?
hello powerstroke.org im currently having problems with my 2006 6.0 and was wondering if someone could point me in the right direction thank you in advance.
About a month ago. i started "building" the truck .
190cc injectors
powermax turbo
58v ficm IDP
IDP custom tunes
Head Studs
new oil cooler
Regulated return
air dog 2
my problem began when i would drive to work about 20 miles . no hard driving just cruising on the highway . when i would pull into the parking lot after driving those 20 miles the truck had a rough idle it did this for 2 weeks last friday i went to leave work and went to crank it over and nothing . i was getting the proper psi on my regulated return so i tried to crank again no longer then 15 sec each time and it started up . smooth idle everything . about half way home from work i noticed my icp voltage . was staying at 4.5 to 4.7v just cruising down the highway . and i was getting a loss of power . when i pulled into my driveway the rough idle was 2x worse and i shut it off before it stalled . i cycled the key to check my fuel pressure again on the return and it still checked out . tried to crank and now it will not start at all . i have not checked my icp pressure yet when cranking and will do that when i get home from work . ficm is getting 48v through my cts . im told that thats the max reading for the monitor thats why it doesnt show more .
i was wondering if anyone else has had this issue ? or if there is anything i can do to narrow down the problem once again thank you for any input
Sent from AutoGuide.com App
06SiXOh is offline
post #2 of 19 Old 05-13-2013, 01:39 AM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Feedback Score: 4 reviews
Unplug ICP and see if it goes away, PCM will sub in values when its unplugged.
Look for oil in the connector.
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #3 of 19 Old 05-13-2013, 01:47 AM
roche837's Avatar
Quoted: 5 Post(s)
Garage
Hopefully your truck is newer that 2004.5 and your icp is mounted on the passenger side valve cover so it can be unplugged easily, if not you got some work to do and might as well change your ICP if your that far into it anyways because its under the turbo on the HPOP cover.
roche837 is offline
post #4 of 19 Old 05-13-2013, 01:48 AM
Semper Fi
TClev's Avatar
Quoted: 2 Post(s)
Garage
I've seen 48.5v on my CTS.
Tony Clevinger
06 F250 6.0L Auto Trans - 129,000 mi
Lariat FX4 CCSB
Toyo Open Country 275/65R20
Bilstein 5100s
Edge Evo CTS
Deleted by Scheid Diesel - Lafayette, IN
Bulletproofed by Reckless Diesel - Dallas, TX
CAT EC-1
Rotella T6
XDP Coolant Filtration
Blue Spring
Turbo Oil Feed/Drain Update
Injen Power-Flow Intake
MBRP 5" Stainless TB
Riff Raff Hot Side CAC Boots
6.4 Starter
Upfitter SEIC
TClev is offline
post #5 of 19 Old 05-13-2013, 03:56 AM Thread Starter
06SiXOh's Avatar
my icp sensor is on the valve cover . i unplugged it and checked for oil . its dry no sign of oil.
06SiXOh is offline
post #6 of 19 Old 05-13-2013, 03:58 AM Thread Starter
06SiXOh's Avatar
when attempting to start the truck this morning it actually started then shuts off instantly . i read my injector control pressure pid on my cts . it spikes around 1550 then dies out instantly .
06SiXOh is offline
post #7 of 19 Old 05-13-2013, 05:34 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Did it throw a code? It should have if the reading was at an unexpected level for a few seconds or more. What was the IPR doing at the same time? As previously stated, unplug it and if it starts consistently and runs at low power levels, your sensor is bad or you have a wiring issue since 4.7v is max pressure.
What happens when you put the tune back to stock? Do the same test on the stock tune. Who knows, maybe the tune is corrupt, but usually the voltage is correct.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #8 of 19 Old 05-13-2013, 01:11 PM Thread Starter
06SiXOh's Avatar
there are no codes thrown . can i check the ipr from my insite? i took the tune off and tried to start it . still not staying running like i said it immediately dies out .
06SiXOh is offline
post #9 of 19 Old 05-13-2013, 01:12 PM Thread Starter
06SiXOh's Avatar
when i attempt to start it with the icp unplug . it still doesnt start . but it is throwing fuel into the cylinder now because theres alot of white smoke coming out my stacks
06SiXOh is offline
post #10 of 19 Old 05-13-2013, 04:58 PM
Quoted: 46 Post(s)
You can see if the IPR is commanded correctly, not that it is working correctly. However, if your ICP was at 4.7v when it shouldn't have been, the IPR was either 85%ish (the truck would run like was stuck WOT) or the volts are wrong from a short. If the circuit to the PCM was reading 4.7v, the IPR would be opening to try and reduce the ICP to normal levels at cruise (about 1100psi or 1.3v(ish). If that was happening during start, the truck would try to start and then quit due to low HPO pressure (IPR opening). Therein lies the problem, you probably have a shorted wire so even if you unplug the sensor, it is still registering 4.7v to the PCM.
Frank
Working for Toys
