Need help in San Diego - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-12-2013, 10:54 AM Thread Starter
So going down the highway, my 04 with the 03 6.0, lost all power, dropped to idle then shut off. It had been hard stating while cold, would have to try three times to get t to run, it also had a jerking kinda like it was misfiring at 45-60 mph while in overdrive gear. Just got this truck only needed it to make until I got back from deployment, then was going to throw money into, that didn't happen. So the egr cooler has been replaced, just changed the icp, had to cut 4-5 inches of wire to get some that had no oil in the wire, also changed harness. I don't have a scan tool that can read real time data, if someone does and is willing to help me out that would be much appreciated. Now while cranking it builds a lot of oil pressure, according to the dash. I have no means of air testing, again if anybody could help it would be much appreciated. Tested the ficm, koeo 48v, while cranking 48v. Just changed the oil and Motorcraft oil filter with Motorcraft filter cap, also just changed the fuel filter with motorcraft filters. Took the EGR valve out and cleaned it, didn't really need it. Right now I really don't have a lot of money to throw into it. If someone in the san diego area can help I would pay. I can give address and phone number. Thank you.
joemffields is offline
post #2 of 7 Old 05-12-2013, 12:56 PM
Slacker
Evil Eye's Avatar
Quoted: 191 Post(s)
Feedback Score: 4 reviews
I wish you were closer because you definitely need a diagnostic scanner and I have AutoEnginuity. Sounds like you have a high pressure oil problem, but to be honest, these symptoms are pretty common, it could have you chasing your tail... I'm not sure how many active folks we have in the SD area, but I'm hoping that something comes through for you. Are you getting any DTC's?
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #3 of 7 Old 05-12-2013, 12:58 PM
xpbprox's Avatar
Give me a call brother . I will help you out. I live in Jamul buy work by downtown SD
Call or text
619-654-1746
I can get your truck on a scanner on Monday
04 F-350 XLT FX4 CC LB SRW leveled, SCT w/ innovative tunes, Edge Insight gauges, Str8 pipe, Studs, Bulletproof EGR, valve seats, 6.4 banjo bolts, updated fuel pressure spring
89 F-350 Centurion Lariat 4X4 CC BB STW lifted on 35"s
460 E4OD
6.0 BIBLE
xpbprox is offline
post #4 of 7 Old 05-12-2013, 02:19 PM Thread Starter
When is a good time to call, I have to work in the morn, but I can get off pretty early.
post #5 of 7 Old 05-12-2013, 02:49 PM
xpbprox's Avatar
Well you can call me today so we can figure something out. Where in SD are you. Shop is located just south of downtown SD. The truck is currently in-op? Correct?
460 E4OD
6.0 BIBLE
xpbprox is offline
post #6 of 7 Old 05-16-2013, 07:49 AM
Xpbprox......you have a diesel shop in San Diego? I may have a need for an oil cooler replacement and am looking for options cheaper than the dealer.
Mromberg is offline
post #7 of 7 Old 05-16-2013, 08:27 AM
xpbprox's Avatar
I work at a shop and we work on everything including diesels. We can take care of you.
Give me a call/text or PM
460 E4OD
6.0 BIBLE
xpbprox is offline
