Stumped HELP - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-10-2013, 10:23 PM Thread Starter
Stumped HELP
Im stumped i have a 03 6.0. Last fri i got about halfway to work and sitting at a stop light i noticed it started idling rough and sounded alot deeper and when i would take off seemed like lack of power. when i left work same thing except steadily got worse till i almost couldnt get it pulled into a gas station as i had it floored or nothing wanted to stall. poped hood i wasnt puking coolant nothing looked out of place oil on dipstick looked fine. finally i took the degas bottle cap and alot of pressure seemed to relese. right after i put cap back on the truck started idling fine and drove through a near by parking lot ran like normal the whole time never had a rise in temperature. ran fine the two times this week drove it untill tonight and it started the same thing with out the wanting to stall butthis time the engine temp went up to high but egt's were where they normaly are. no codes, no coolant puking from degas bottle, i have noticed past few months under driver side floormat it stays damp even after drying it out. im completely stumped PLEASE help
bigrebel is offline
post #2 of 9 Old 05-11-2013, 06:12 AM
twoicebergs's Avatar
Quoted: 43 Post(s)
What is the HPO pressure doing when this is happening? Since it seems so severe, but recovers, it might be an IPR issue. However, since you didn't give us much info to work with, it could be caused by a variety of issues: FICM, fuel, etc.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 9 Old 05-11-2013, 06:28 AM
ADMIN AND TECH
SCUFFY828's Avatar
sounds to me like you have more than one issue , idling and running funny issue sounds like ipr or icp problem, puking coolant issue may be an egr cooler or head gaskets
in my opinion this truck needs some one to spend some time with a scanner , monitoring icp voltage , ipr percentages , what codes are in system if any , monitor ect and eot temps
ITS STOCK
SCUFFY828 is offline
post #4 of 9 Old 05-11-2013, 09:50 AM Thread Starter
soory for lack of info i been waiting on a buddy of mine to hook it up to his computer. until then im in the dark myself its not puking matter of fact thats kinda what has me stumped when i took the degas bottle cap off it seemed like there was to much pressure built up but before i took the cap off it wasnt hissing or anything. twice when ive started it it started and was idling way down in the high 400rpm low 500rpm then pick up after a few seconds but still idle rough. it does seem like ive lost a small amount of coolant but there doesnt seem to be any coolant in my oil and it isnt coming from my tail pipe that me or my buddy or dad have noticed while watching it. at first we were thinking hpo problem but when the engine temp went way up right to the verge of overheating made me think more on lines of egr cooler or head gaskets or something along those lines. i have noiticed my driver side floor board being damp and was wondering if i got a blockage in my heater core and leak that could be causeing it? and im not throwing any codes on a basic scanner but when i get the computer hooked up i think ill have a better idea what going on
bigrebel is offline
post #5 of 9 Old 05-11-2013, 09:57 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
maybe your ficm is at an extreme low voltage.. honestly it could be a million things let us know some numbers your buddy gets with his scanner.
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #6 of 9 Old 05-11-2013, 09:53 PM
Quoted: 43 Post(s)
Since your cap held the pressure, it is unlikely you have a coolant/headgasket problem. As long as the coolant returns to the same level (cold), you don't have a leak to find. The monitor or diagnostic tool should give the tell-tale info to figure out cause of the low idle.
Frank
Working for Toys
post #7 of 9 Old 05-13-2013, 07:06 PM Thread Starter
well i did a block test today and it come back all good but i did notice when i added some coolant while it was running and turned the heat on to circulate it completely that it got a little rougher idling but would level out (but still idle rough) when i turned the heat off. still havent put it on the computer yet. but i had a few buddies tell me that it might be my heater core that would be where the damp driver side floor board and slight coolant loss would be coming from so before i go jumping to far into things im gonna try the heater core and a new thermostat and flush the coolant system and delete the egr see what happens
bigrebel is offline
post #8 of 9 Old 05-15-2013, 04:37 PM
sonds's Avatar
I would think you would be smelling coolant in the cab if your heater core is shot.
05 f-250 CC
4" MBRP turbo back kitty delete
EGR valve and cooler delete
Cat coolant
CAI
Edge Insight
Dieselsite coolant filter
Swamps 58v ficm
sonds is offline
post #9 of 9 Old 05-19-2013, 10:29 AM Thread Starter
Just a update but finally yesterday figured out it was the fuel pump. Put the new one in starts right up runs good and my buddy data logged when we took it for a test drive and everything checked out good but I do still know the heater core is leaking so that and some other stuff going on next weekend
bigrebel is offline
