05 Loses power, idles rough, sometimes dies. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-10-2013, 05:07 AM Thread Starter
badyota82's Avatar
This is a good friends truck, and I haven't personally experienced the problem on his truck, so details may be a bit vague, but I will do my best.
Truck is an 05. Took it to the local PSD guru for a hard cold start and rough idle. I thought it may be injector stiction, so I hooked up my CTS to it and had cylinder contribution codes for all 8 cylinders, and the FICM voltage was a little low. So they replaced the FICM with a new ford unit, so I'm told, and now it will run fine, then all of a sudden start dropping power to the point where it won't hardly do 40mph, then when he stops it idles rough and will sometimes die. He has told me that if he turns it off and restarts, most of the time it will run fine again, bit then repeats the whole process. It is now sitting back at the mechanics shop, and he has a HUGE backlog, and my pal needs his truck back so I'm trying to help him out through the advice of the forum.
I am wondering if its an ICP sensor or and IPR that is causing the problem, but hard to say for sure.
Thank you in advance for any help!
Sent from AutoGuide.com App
2006 F250 Lariat CC FX4
Current Mods:
4" MBRP Exhaust
58v FICM w/ performance flash
Blue FPR Spring
SCT w/ tunes from Matt (SRL, 8k Tow, Unlim. Tow)
Edge Insight CTS
1200rpm High Idle
Coolant Filtration System
6.4 Banjo Bolts
ARP Head Studs
EGR Delete
Sold: 1997 F250 PSD 4x2 5 speed
badyota82 is offline
post #2 of 3 Old 05-10-2013, 05:32 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Egr valve sticking would cause this pull and clean the egr valve. It could be a fuel filter issue as well. You need to invest in a monitor such as scan gauge or edge ct so we can get a good look at what your engine is doing and pull the codes again.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 3 Old 05-13-2013, 05:45 PM
Same thing happened to me, it turned out to be my #8 injector gone bad
TomTheToolman is offline
