2004 6.0 with 2003 motor misfire? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-10-2013, 04:58 AM Thread Starter
jake_duet's Avatar
The other day, i noticed when i left for work that my truck was having a hard time taking off with a lot of spitting and sputtering. Then it takes off with a lot of power. Im throwing a p0266 code SOMETIMES. It also takes forever to go even when you try and take off. Any help would be appreciated.
Early build 2004 Ford F-250 6.0
S&B Intake
EGR Delete Kit
4" Diamond Eye Turbo Back Straight Pipe
blue spring upgrade
updated oil cooler
Edge Insight CTS monitor
GlowShift boost, fuel psi, and oil psi gauges in pillar pods
08 tail lights, 05 headlights
Mf. Date July, 2003
"Keep on Strokinn"
jake_duet is offline
post #2 of 2 Old 05-10-2013, 05:41 AM
dxusmc's Avatar
got anything to monitor FICM voltage? When my FICM was on the fritz my truck had a problem getting out of its own way.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
Tags
hard takeoff , misfire , p0266
