coolant smell - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-09-2013, 01:26 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
coolant smell
When I park my truck after driving it I'm getting a coolant smell no puddles under it but there seem to be a little on the exhaust manifold on the drivers side. Could it be coming from the degas bottle?? If so what does this mean HGS?? I sure hope not not ready for that yet.
04fording is offline
post #2 of 4 Old 05-09-2013, 03:52 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 274 Post(s)
Could just be a split in the bottle. Pressure the system manually, and snoop around
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #3 of 4 Old 05-09-2013, 03:56 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
OK I know its holding pressure I'll just look as soon as I shut the old goat down.
post #4 of 4 Old 05-09-2013, 05:28 PM
No reason to panic yet it could still be just a bad cap, the cap vents at 16 psi.
You say the system held pressure, ok to what pressure did you test to? Did you test with a test pump?
Normal operateing pressure is from 12 to 15 psi with 15 psi crowding the limit.
You can test system pressure with the same hand pump, leave it hooked up but do not pump,run the engine and read the pressure it should not exceed 15 psi. A rapid rise in pressure to above 15 indicates you are getting combustion gas in the coolant useually do to blown egr cooler or head gaskets. Further testing required.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
