Low oil pressure, help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-09-2013, 11:19 AM Thread Starter
Max-'s Avatar
I am on my way to work and the low oil pressure buzzer keeps going off. The needle stays normal until I slow down at a light then drops to L. If I barely give it throttle it jumps back up. I use the Torque app and it is saying at a idle that hpop is reading 578-597. Any info please. Thanks
Max- is offline
post #2 of 6 Old 05-09-2013, 12:12 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Try checking the sensor. Also what filter and cap are you using for your oil?
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 6 Old 05-09-2013, 04:27 PM Thread Starter
Max-'s Avatar
I am using the factory cap that has always been on there (black) and I use Ford filters, changed oil approx 2500k ago. Will try and look up where sensor is.
Max- is offline
post #4 of 6 Old 05-09-2013, 05:39 PM
Powerstroke Techie
Quoted: 17 Post(s)
Garage
Feedback Score: 4 reviews
I usually start by replacing the sensor and the pigtail, you may find it's leaking internally and has contaminated the connector. Very common for these to go bad
I've gotten burned by not replacing the connector too
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 6 Old 06-25-2013, 05:11 PM
Where is the sensor located?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #6 of 6 Old 06-25-2013, 05:13 PM
SAILOR97's Avatar
Quoted: 4 Post(s)
Sensor is located right behind the oil filter....I just changed mine for erratic readings....there's also a 6.0l engine app you can download that will show
Component locations
Edge CTS Insight w/turbo timer, EGT probe, Fuel pres., SCT X4, DC Power 185 amp alt., NUC Motorsports deluxe oil bypass, Rotella 5W-40 W/Rev-X, Sinister Coolant Filtration, ZEREX CAT ELC-1, Dual Exhaust Stacks.
SAILOR97 is offline
