Dealer is throwing parts at my truck - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-08-2013, 03:34 PM Thread Starter
fbrewer's Avatar
Background: One day I started up my truck coming out of a store, so the truck was warm. It didn't sound exactly right, but nothing alarming. Driving down the road it felt like I had very slow throttle response. Stopped at a light and it wouldn't pull its own weight from a stop. I started to limp over to the curb and the truck stalled. Started it up again and it ran like nothing was wrong. It ran perfect for more than a week. Started it up one morning and it definitely didn't sound right (clanging and chattering). I suspected the FICM and tested the voltage. Sure enough the voltage running was 34 volts (48v normal). So I ordered a new voltage side of the FICM, but it didn't fix the problem.
So here is where it gets incredible. I take it to the dealer and here is how it has gone:
  • Day 1: I need a new Cam position sensor $500+
  • Day 2: I have gasoline in my fuel (no idea how that could happen). Drop and drain fuel tank and flush fuel system: $600+
  • Day 3: Both Batteries are bad (just had them tested 3 weeks prior): $250
  • Day 3: FICM and all 8 injectors are bad. I tell them about the new voltage side, but the computer board could be bad. Tell them to replace the FICM and test the injectors again: $1025
  • Day 4: All 8 injectors still not cycling. Replace injectors: $2875
  • Day 5: running but will stall if they let it fall below 1000 RPM. Tell me the IPR valve is bad. It is only a few months old, I replaced it when I put on a new Turbo, Y-pipe and exhaust. They covered the IPR under warranty
  • Day 6: Still not running right, still working on it, they have not called me back.
I took it to the Ford dealer to avoid throwing parts at it and it seems like that is exactly what they are doing. I could have done that for a lot less money.
Any thoughts?
Cincinnati, Ohio - 2005 F350 XL FX4, SRW, Crew Long bed. Glow-shift pillar gauges, By-pass oil filter, EGR Delete
fbrewer is offline
post #2 of 10 Old 05-08-2013, 04:09 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Sounds like you should take it to someone more reputable.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 10 Old 05-08-2013, 08:15 PM
JustinOOO9's Avatar
Quoted: 524 Post(s)
Garage
you need to run from that dealer as fast as you possibly can!!!! that is what a uncertified ford dealer does to ppl. im really sorry man... find someone who can show you the 6.0 certificates the 6.0's are incredibly complicated and when idiots work on them and can't properly diagnose them....
have you checked fuel pressure/ filters?
also a guy found his fuel pump assembly was clogged about 2 days ago....
open up your filter in your engine (the small) black cap next to oil filter and let your truck prime and see if your cup fills. also the wire harness for the FICM was notorious for rubbing through in some spots. go to FICMREPAIR.COM they have some articles with pics to help.
run from that dealer before you refiance your house they'll help sign the papers for parts money.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #4 of 10 Old 05-09-2013, 04:40 PM
f350powerstroke's Avatar
Get that truck away from that dealer!
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #5 of 10 Old 05-09-2013, 05:23 PM
Quoted: 822 Post(s)
Run Forrest run.
Corey@CNCFAB is offline
post #6 of 10 Old 05-09-2013, 07:32 PM
Louiediesel's Avatar
run,run and don't look back,that really sucks they ripping you off that way.
Louiediesel is offline
post #7 of 10 Old 05-09-2013, 08:08 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1713 Post(s)
Any thoughts?
Yah your coming up on 6k and they still havent fixed it. Your going to need to raise hell at payment time. This is BS there is no way they are following the pinpoint tests for the issues the truck has. Sounds to me like a truck I just got done with. It had a shorted map sensor that was throwing all of the other sensors off. Truck had the same symptoms as yours. Took me 3 hours to pin it down but in the end the customer was back on the road for under 500. The whole reason you are paying for diagnosis is for them to tell you what will FIX the truck. Not what they think is bad. You need to tell the service writer when he calls back with the next thing thats wrong, if it doesnt fix it your not paying for it. I agree with the above statements...Once you get her back run from that dealer and find somone that knows the 6.0 better.
toren302 is offline
post #8 of 10 Old 05-11-2013, 08:36 AM
mustangmike6996's Avatar
i would have said F*** no after the first failed diagnostic attempt. also, tell them you want all of your old parts back (that arent warranty because those will be turned in most likely)
mustangmike6996 is offline
post #9 of 10 Old 05-11-2013, 08:55 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
I'm confused, I thought dealers only threw parts at vehicles till they worked and let you foot the bill...
Sorry you had to learn that the hard way, but I wouldn't let them touch your rig anymore.
Good luck.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #10 of 10 Old 05-11-2013, 09:01 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i bet dobbs woulda done a better job.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
