05 f30 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-08-2013, 03:16 PM Thread Starter
Question 05 f30
truck runs fine for about 30 or 40 miles then shuts off by it self and wont turn back on until i let air out of the top fuel filter and then starts up and runs fine but then does it again anyone have any good ideas it could be
05f3504x4 is offline
post #2 of 2 Old 05-08-2013, 06:32 PM
are your fuel filter caps on tight? check your fuel pressure, could be a bad fuel pump to if you have to purge the system with fuel(getting the air out)
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
