Fuel injector issue - Ford Powerstroke Diesel Forum
post #1 of 20 Old 05-07-2013, 01:07 PM Thread Starter
Fuel injector issue
Ok well I'm pretty sure I have a fuel injector problem that is causing my engine to run rough. I have checked everything and all checks out ok great my Ficm voltage fuel pressure everything. It happens when it's cold but also comes and goes when it's warmed up but not as often as cold. My question is there an easy way to know what injector is acting up? Doesn't throw codes or anything when it does act up just runs rough and smokes like a chimney? Any help would be appreciated
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
post #2 of 20 Old 05-07-2013, 01:25 PM
It should throw a code, if its bad enough.
flatblk is offline
post #3 of 20 Old 05-07-2013, 01:37 PM Thread Starter
Ya it must not be bad enough cause it doesn't throw a code at all... But it's enough to shake it pretty good when it happens... Lol its really wierd
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
post #4 of 20 Old 05-07-2013, 01:46 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
The only way is to use a diagnostic tool or disconnect each injector to find the culprit. The latter method is a PITA due to all the wires and accesories in the way. Don't loose the harness clips or it will cost you dearly.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 20 Old 05-07-2013, 02:14 PM Thread Starter
So the only way is taking it to ford? Lol wish I knew which one it was so I didn't have to take it to them
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
post #6 of 20 Old 05-07-2013, 03:37 PM
Quoted: 47 Post(s)
There is nothing wrong with a good shop giving you the diagnosis. But if you don't want to take it in, find, borrow or buy an autoenginuity with ford bundle. 3 tests an it is paid for.
Frank
Working for Toys
post #7 of 20 Old 05-07-2013, 03:46 PM
I just dropped my truck off this afternoon at the dealership for a similar problem. I didn't find any codes when I check it with my autoenginuity with the ford bundle. The service manager said it might be a bad injector cup but he wasn't sure.
07 F-250 CC SB Fx4, 4in Exhaust, SCT w/custom tunes, Edge Insight, Mishimoto Radiator, BPD Water Pump and Oil Cooler, EGR delete, and a big wishlist...
RabbMan 6.0 is offline
post #8 of 20 Old 05-07-2013, 03:51 PM
Quoted: 2 Post(s)
What are your trucks symptoms?
Troy K.
2003 Ford F-250 6.slow w/240K
4" Turbo back exhaust
SCT X4
XDP coolant filter
Blue Spring
315/75 BFG MT's on American Racing rims
Leveled
5100's
And way more time and money invested than its worth
Turk.919 is offline
post #9 of 20 Old 05-07-2013, 03:51 PM Thread Starter
Damn this is a pain I'll probably have to take it in and have them try to find the problem.. I hope it's not something I can't do
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
post #10 of 20 Old 05-07-2013, 03:55 PM Thread Starter
It runs ****ty and blows smoke almost like it's miss firing on a cylinder for for a while then it goes away and runs fine... It happens more on cold start ups more than anything... But it's very sporadic when it happens. Sometimes last for a while others it does it for a minute and stops. Tried injector cleaner changed oil changed the icp sensor still does it
04 Powerstroke
Scan gauge
Exhaust temp gauge
Studs (Finally)
with a 4" exhaust
tylerw13 is offline
