Fuel pressure drop at WOT after 60mph - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-07-2013, 04:18 AM Thread Starter
mxrider777's Avatar
Just replaced my HFCM (fuel pump) on my 2003 6.0 cause i thought it would fix my fuel pressure dropping after 60 mph, My fuel pressure fluctuates at idle between 63-66 and after WOT from a stop drops to 55 then after 50-60mph(still WOT) starts dropping past 50psi,Any suggestions? I have the blue spring with a bb
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
sinister coolant filter
zerex elc coolant
edge insight
Egr Delete w/ coolant reroute
mxrider777 is offline
post #2 of 17 Old 05-07-2013, 04:51 AM
Quoted: 770 Post(s)
Fuel filter???
Corey@CNCFAB is offline
post #3 of 17 Old 05-07-2013, 05:53 AM
Quoted: 2 Post(s)
^ +1, I noticed a substantial power increase with good filters. But if you are running oversize injectors that are not listed you need a bigger fuel system. Also try a regulated return if the filters are good.
Troy K.
2003 Ford F-250 6.slow w/240K
4" Turbo back exhaust
SCT X4
XDP coolant filter
Blue Spring
315/75 BFG MT's on American Racing rims
Leveled
5100's
And way more time and money invested than its worth
Turk.919 is offline
post #4 of 17 Old 05-07-2013, 06:25 AM Thread Starter
mxrider777's Avatar
i Juts changed my fuel filters about 1000 miles ago and stock injectors, and no tune, thats why im confused?
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
post #5 of 17 Old 05-07-2013, 06:30 AM Thread Starter
mxrider777's Avatar
Filters are motorcraft
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
post #6 of 17 Old 05-07-2013, 12:17 PM Thread Starter
mxrider777's Avatar
Another note: the fuel pressure gauge reads 0 when i turn the key on and i wait for it to build pressure (66 psi) every time before i start it, so it seems like it wont hold any pressure when sitting for 5 minutes (off) , I dont know if this is normal but i dont think it should be
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
post #7 of 17 Old 05-07-2013, 09:36 PM
Exactly how are you readinge fuel pressure a aftermarket gauge of some kind.
No 6.0 ever built came with a fuel pressure gauge.
Fuel pressure bleeding of after a few minutes is normal, it is why the fuel pump comes on when you turn on the key and why your owners manual says to wait a few minutes before starting the truck that and a few other things to complete their cycles.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #8 of 17 Old 05-08-2013, 05:10 AM Thread Starter
mxrider777's Avatar
I am using this gauge
square fuel pressure Gauge, velcro anywhere, size of a keychain remote. Digital fuel pressure gauges in a square package will read fuel pressure in PSI. - square fuel pressure Gauge, velcro anywhere, size of a keychain remote
I know another forum member is using this same one
I agree with you, but after the pump shuts off it doesnt hold any pressure it drops to zero very fast, the pump is also louder then normal (motorcraft)
I just think it should hold some amount of pressure and with a new pump i would of expected my fuel pressure to be higher then it was and its the same 66 at idle and 57 at WOT
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
zerex elc coolant
edge insight
post #9 of 17 Old 05-08-2013, 09:56 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Does the 2003 fuel tank have the filter set up in it?? Also 57 psi at wot is good pressure.
Did you look at the condition of the fuel poppet in the regulator. may have some damage in the seat ?
Again the pressures you are seeing are not really bad, but you are squashing the blue spring.
Does the fuel pressure drop the longer you drive it? If so look into the tank filters if so equipped.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #10 of 17 Old 05-09-2013, 07:52 AM
On mine, once the fuel pump shuts off the pressure bleeds down to zero pretty quickly. I think it is normal.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
