Replaced Injector and loss oil pressure - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-06-2013, 06:08 PM Thread Starter
Louiediesel's Avatar
I put a new injector (#6) started up the and truck was running great, wanted to let it run to work the air out of the oil, stoped at wallys to get some stuff, let the truck idling and came back out 10 minutes later to find the fire and police dept. looking for the owner (me) because it was smoking so bad and nacking like crazy , NOT oil pressure in the dash board gage....WTF !!! I"m puzzeld any ideas what it could be anybody ? thanks
Louiediesel is offline
post #2 of 6 Old 05-06-2013, 06:49 PM
nicked an o-ring on the injector, blown injector or stuck open injector, broken hold down bolt or improper torque on the bolt etc.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 6 Old 05-07-2013, 05:47 AM Thread Starter
Will an stuck open injector make you loose the oil pressure ??
post #4 of 6 Old 05-07-2013, 11:28 AM Thread Starter
found out......improper torque on the hold down bolt,took it out seens ok will retorque to specs and try it again
post #5 of 6 Old 05-07-2013, 11:56 AM
Bump To Pass!!
toren302's Avatar
Quoted: 1680 Post(s)
Make sure you blow the hold down hole out with air. Oil will hydraulic the bolt make it feel torqued.
Sent from AutoGuide.com App
toren302 is offline
post #6 of 6 Old 05-07-2013, 04:16 PM Thread Starter
got her runing again, smoke for bout 10 minutes , now is running good ,going to change the oil again just in case some diesel got in there, thanks for imput guys !!!
