6.0 wont start - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-06-2013, 07:08 AM Thread Starter
Anti-Hashtag Member
starcommtrey1's Avatar
Quoted: 488 Post(s)
6.0 wont start
Truck will turn over and over them hit and die. One code P0863. Any ideas? 45-50 degrees outside
Only two defining forces have ever died for you, one died for your soul, and the other died for your freedom. They are Jesus Christ and the American Military Service member. So, pray to God for your soul, and Thank a Veteran for the right to do so.
2007 King Ranch CC F-350 SRW
Performance Machines EGR Delete
Performance Machines Coolant Filter
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
starcommtrey1 is offline
post #2 of 12 Old 05-06-2013, 07:28 AM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
Do you mean P0683? Most likely a bad GPCM
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #3 of 12 Old 05-06-2013, 07:29 AM
Quoted: 5 Post(s)
Check FICM voltage. Should be 48V while cranking.
There is an inspection cover on the top of the FICM. Remove it and check the pin closest to the drivers side of the truck should be 48V.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #4 of 12 Old 05-06-2013, 07:36 AM Thread Starter
Anti-Hashtag Member
Quoted: 488 Post(s)
Yes sir i meant that
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #5 of 12 Old 05-06-2013, 07:38 AM
Quoted: 275 Post(s)
P0863 is a transmission code, thats why it didnt make sense.
post #6 of 12 Old 05-06-2013, 07:51 AM Thread Starter
Anti-Hashtag Member
Quoted: 488 Post(s)
Any way to test it?
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #7 of 12 Old 05-06-2013, 07:52 AM
Quoted: 5 Post(s)
The glow plug module is not why the truck is not starting.
Check FICM voltage:
05 Extended Cab FX4
Ble-Blah mod...
a2elvis is offline
post #8 of 12 Old 05-06-2013, 08:45 AM Thread Starter
Anti-Hashtag Member
Quoted: 488 Post(s)
I know how to check the ficm. Assume it is working how do i check the gpcm?
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
post #9 of 12 Old 05-06-2013, 09:39 AM
Quoted: 275 Post(s)
Using an amprobe on each of the harness that feed each buss bar
post #10 of 12 Old 05-06-2013, 10:42 AM Thread Starter
Anti-Hashtag Member
Quoted: 488 Post(s)
Ok. It warmed way up and i had someone try to start the truck. Fired right up....so is that for sure the gpcm?
Blue Spring Mod
SCT Tuner
Straight Piped
Custom Tunes by MPT
Mishimoto Radiatior
