Clutch fan wiring - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-06-2013, 06:45 AM Thread Starter
Pistolgrip426's Avatar
Clutch fan wiring
I have an 04.5 with a hydraulic pto pump mounted on engine, anyhow belt broke and sliced wires from engine harness to clutch fan, new clutch has different wire color codes, anybody have wiring diagram ? My plastic plug pigtails were destroyed. Need to hardwire system, my fan is not engaging properly. Thanks
2004.5 F-550,4x4,6.0,auto,CTS monitored,
Performance Machine egr delete,caterpillar elc,blue spring, CTS Monitor,flat plate agm batteries,K8 code, super tow pkg. (4.88),twin line recovery wrecker.
Pistolgrip426 is offline
post #2 of 7 Old 05-06-2013, 07:11 AM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 276 Post(s)
I dont know if this helps, its for 2003.25, but it may may be a starting point. Check out pages 90 and 91, if you have single alternator anyway....Powerstroke 6.0L Technical Intro Manual
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #3 of 7 Old 05-06-2013, 11:10 AM
Quoted: 276 Post(s)
Maybe this will be of more help....DTS Articles - Coffee Table Books
post #4 of 7 Old 05-06-2013, 08:23 PM
here ya go.... this is the harness side. Cannot find the component side.
Mike B
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #5 of 7 Old 05-07-2013, 05:17 AM Thread Starter
Thanks fella's
post #6 of 7 Old 07-05-2014, 03:17 PM
I found this wiring diagram for the fan clutch helpful. Does anyone know where I might be able to buy a new pigtail plug on the harness (engine) side? Or the entire harness? I damaged the pigtail and now my fan doesn't engage properly. I don't really want to hard wire it, unless I have to. The clutch side is brand new, I hate to cut it off.
krwsenior is offline
post #7 of 7 Old 07-05-2014, 03:55 PM
I meant to say - other than from the local Ford dealer. I have been looking online at many sites and found a lot of plugs, but not that particular one.
