2006 F250 6.0 Diesel Replaced Heads and ran for an hour, now won't start - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-05-2013, 07:46 PM Thread Starter
frogjaw's Avatar
Exclamation 2006 F250 6.0 Diesel Replaced Heads and ran for an hour, now won't start
I replaced the heads on a 2006 F250 6.0 Diesel, put it all back together and started it up. It ran great for about an hour , then it started cutting out. I killed it and it took a little bit to restart it, spinning over and over to get it to run, this took place several times. The engine died and now it will not start. I keep getting codes P2284 and P2290. Any ideas what could be causing this problem?? When you turn the key on the fuel pump comes on and the injectors pulse, but when the pump shuts off the injectors quit pulsing. When you try to start vehicle the injectors still won't pulse. Could this be the cam or crank sensor? The tester reads 40, Idk if this is enough volts to open the injectors.......
frogjaw is offline
post #2 of 10 Old 05-05-2013, 07:47 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Are you getting com between the obd2 port and ECU? Sounds like something chaffed or rubbed through
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #3 of 10 Old 05-05-2013, 07:59 PM Thread Starter
frogjaw's Avatar
It is communicating. This all started after I changed the head gaskets, I keep getting ICP codes........ but when I unhook the ICP it still won't start so I don't think that's the problem......
frogjaw is offline
post #4 of 10 Old 05-05-2013, 08:01 PM
Winning DUHHH
Quoted: 8 Post(s)
Hmm, no start either way?
Check your harnesses for chaffed
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
post #5 of 10 Old 05-05-2013, 08:55 PM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
Pull the IPR and check the screen for trash.
Please
You could save the life of a sick child
NYC F-350 is offline
post #6 of 10 Old 05-06-2013, 06:03 AM Thread Starter
frogjaw's Avatar
I located the IPR, the connector or maybe even the whole housing seems really loose. Is this normal?
frogjaw is offline
post #7 of 10 Old 05-06-2013, 09:55 AM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
Yes its normal. Thats just the coil on the armature. Some are a tighter fit than others. As NYC F-350 suggested, pull the IPR and inspect. 2290 is a low ICP code so that steers you in the direction of a HPO leak somewhere
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #8 of 10 Old 05-07-2013, 09:17 AM Thread Starter
frogjaw's Avatar
I pulled the IPR off to inspect it, the screen was broken and I found two wires touching under the turbo...... It runs GREAT now!! Thanks for all the help guys!!
frogjaw is offline
post #9 of 10 Old 05-07-2013, 05:26 PM
This site rocks!
01 F-350 reg cab srw 7.3
Important stuff:
Beans stage 1 injectors, Beans 6 position chip
Dieselsite ww2, boost fooler, wastegate controller
gauges, upgraded up pipes,
afe intake, 4" flow through muf w/turn out
BTS transmission, 6.0 cuuuler
35"toyo mt on 18" black kmc addicts
06 F-350 cc srw 6.0 lariat
build being planned...starting with the cab off
frashdog is offline
post #10 of 10 Old 05-08-2013, 06:41 AM
Winning DUHHH
Quoted: 8 Post(s)
Glad she's running!
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
