Intermittent lack of power - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-05-2013, 02:49 PM Thread Starter
OK. I have a 2006 6.0. I have an intermittent lack of power. Seemingly random times. Some days it never does it. Some days it does it alot. When it occurs the injectors seem to get real quiet. Fuel pressure is good and does not drop while the problem is occurring. I have checked the FICM voltage and it checks out fine, though I have never been able to check it while having the issue.
Ideas?? Chafed FICM wires? Could it be the FICM? I have been searching the forums on several sites to no avail.
No DTCs. It has the blue spring upgrade. I just had the EGR out and cleaned up hoping it was that, but alas still doing it...
I have not owned the truck long. It seems the previous owner may have not maintained the truck very well, judging by the maintenance I have done.
ksturner01 is offline
post #2 of 6 Old 05-05-2013, 02:56 PM
Term3's Avatar
Could be sticking turbo vanes. There are a number of "How to do it" out there.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 6 Old 05-05-2013, 03:00 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 275 Post(s)
Check your ICP sensor and pigtail for any visual abnormalities
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #4 of 6 Old 05-05-2013, 03:04 PM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
The pigtail is specific to the 03 ICP. 04 and above, the ICP is in the passenger side valve cover.
Definitely sounds like a high pressure oil problem. Monitor ICP pressure and IPR duty cycle and verify both readings during power loss and see how that compares to when you feel like you have full power. It could be several things in the high pressure oil distribution system on your 06.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #5 of 6 Old 07-19-2013, 08:43 AM Thread Starter
Update:
I have not had the problem since the weather got warm...
post #6 of 6 Old 07-19-2013, 09:00 AM
JUGGS's Avatar
subscribed, and welcome to the ORG
2005 F250 Lariat CCSB/170k mi./6sp Handshaker
Don't Worry
Dieselsite coolant filter, CAT ELC, Bulletproofed and monitored by BPD
Be Happy
SCT SF3, 4" Flo Pro, 2.5" Readylift SST, 35" GoodYear Fierce Attitude M/T's
JUGGS is offline
Tags
injector , injectors , intermittent , lack of power
