06 6.0 hard to start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-03-2013, 10:17 AM Thread Starter
KingInfamous's Avatar
Went to start the truck and it would crank fine and start normal then die. To get it to start and run i had to half throttle it for about 30 sec then it ran fine. After getting down the road a ways it through the trouble codes p0261 p0264 p0267 p0270 p0273 p0276 p0279 p0282 p0343 and p0611. I have no idea why it through all the codes at once.
KingInfamous is offline
post #2 of 6 Old 05-03-2013, 11:10 AM
My guess would be a FICM going out. What kind of FICM voltage are you showing?
2005 F-350 Lariat FX4 6.0L CCLB DRW - MagnaFlow exhaust, K&N intake, Edge Insight CTS, BPD bypass oil filter, DS coolant filter, Looney Fuel tune by Vivian, blue spring
Rev_GAS is offline
post #3 of 6 Old 05-03-2013, 02:25 PM Thread Starter
havent had a chance to meter it yet. the ficm going would cause the cam position sensor code to pop?
post #4 of 6 Old 05-04-2013, 06:00 AM
dxusmc's Avatar
a no start condition during extended cranking will cause the cam and crank sensors to throw a code. Make sure your batteries are giving enough juice but I agree with Rev, need to get yourself a voltage reading Key On, Engine Off then Cranking, and running (if it starts)
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #5 of 6 Old 05-04-2013, 06:06 AM Thread Starter
truck starts and runs fine my buddy is on his way over with the meter to test the voltage.
post #6 of 6 Old 05-04-2013, 06:28 AM
Term3's Avatar
Great time for a BPD FICM upgrade.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
