P0470 Even after new EBP sensor - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-03-2013, 04:55 AM Thread Starter
Hi there,
Got a 6.0 that keeps putting the check engine light on for P0470, I removed the EBP sensor replaced that and cleaned the tube, The code then went away for around 10 days. I now am getting the code again. Any idea what to check now could it be a faulty sensor? How can I test the sensor?
Regards
Phil
Phi1 is offline
post #2 of 2 Old 05-03-2013, 06:28 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
P0470 – Exhaust Pressure Sensor
Typical Monitoring Duration: P0470 –Greater than 5 seconds.
You could have a wiring issue if you had this come back. It is unlikely the new sensor is the issue.
Your best course of action would be to see if you have a plug or wire issue first. If you know the wires are OK, you can test the sensor with shop air with an adapter or even a rubber nub. It is a 5v 50psi pressure sensor, so you can do it on the bench if you had a spare plug and voltage tester. One wire is 5vref the other is ground and the 3rd is gauge related.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
