Longer crank time!!! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-02-2013, 06:43 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
The last few times I have gone to start my truck it is cranking a lot longer before it finally fires. This has just started want to get on it now before it gets worse.
04fording is offline
post #2 of 13 Old 05-02-2013, 06:49 PM
Is it an early 04? or a later 04?
Also check your oil filter canister for drain back.
May not be the problem but its something easy to start with.
Evan@CFD is offline
post #3 of 13 Old 05-02-2013, 06:51 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
OK changing oil tomorrow. Its an Early 04.
post #4 of 13 Old 05-02-2013, 06:51 PM
04cr450's Avatar
you have a monitor? you need to check fuel press, icp, etc etc
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 13 Old 05-02-2013, 06:52 PM
Does it take longer to crank hot or cold, or both?
Do you have any sort of monitor on the truck?
berusch is offline
post #6 of 13 Old 05-02-2013, 06:54 PM
16oz of archoil in the oil made a big differences in how quickly my truck starts cold.
berusch is offline
post #7 of 13 Old 05-02-2013, 06:55 PM
On an early 04 you have the older style oil pump which also have a rounded pipe that is also know to rub through sometimes.
But im with 04cr450, If you have that capability to check all those you should try that.
If you don't it would be worth it to find someone that can.
Evan@CFD is offline
post #8 of 13 Old 05-02-2013, 06:57 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
No monitor. Its more so when its cold.
post #9 of 13 Old 05-02-2013, 06:59 PM
Could possibly be a glow plug issue.
Or a fuel supply issue.
Evan@CFD is offline
post #10 of 13 Old 05-02-2013, 07:09 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
Umm. I still haven't done my blue spring update yet either. Its getting fuel filters tomorrow to since the weather is warming up I do them right before winter and after winter. I'm late this year but I'll knock those couple of things out and see how turn out after that.
