I have no top end... - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-30-2013, 05:51 PM Thread Starter
black03's Avatar
Like title states I have no top end power it says I have 27 pounds of boost and my map psi is 40 but no go its slower than a 1.2 l jetta...... I have a MTw hybrid, edge evolution on high, ( I know I know saving for a SCT) and deleted and studded....
2003 F350 PSD 6.0, Airlift Airbags front and rear. custom 4 inch-5inch exhaust. zoodad mod, ARP head studs, EGR delete, PMM Titanium head gaskets, MAD turbo werks hybrid, more to come
black03 is offline
post #2 of 16 Old 04-30-2013, 05:58 PM Thread Starter
black03's Avatar
Plus my turbo flutters every time I let off the throttle.
black03 is offline
post #3 of 16 Old 04-30-2013, 06:13 PM
What's your fuel pressure at wot?
Moto2four is offline
post #4 of 16 Old 04-30-2013, 06:16 PM Thread Starter
black03's Avatar
That's a good question, I don't have a fuel pressure gauge
black03 is offline
post #5 of 16 Old 04-30-2013, 06:51 PM Thread Starter
black03's Avatar
How would I go about getting that checked??
black03 is offline
post #6 of 16 Old 04-30-2013, 07:13 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1738 Post(s)
Should also check you HPO readings. Just had an 03 in that made 30PSI out of the turbo but only 1400psi worth of high pressure oil under WOT. Needed a HPOP and all was good.
toren302 is offline
post #7 of 16 Old 04-30-2013, 07:27 PM Thread Starter
black03's Avatar
I hope its not my hpop! I can't afford that I also need an oil cooler its starting to have a bigger delta difference
black03 is offline
post #8 of 16 Old 05-02-2013, 10:33 AM Thread Starter
black03's Avatar
Well got my hpop tested and they say its fine.... now what??
black03 is offline
post #9 of 16 Old 05-02-2013, 10:50 AM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 10 Post(s)
How long you been running that MTW turbo?
-Julian
4th 6.fo
TwinTurboStroker is offline
post #10 of 16 Old 05-02-2013, 10:50 AM
Still need to check fp. Is it smoky at wot? What's you ficm voltage?
