Need help with diagnosing a fuel pump! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-30-2013, 02:37 PM Thread Starter
2005 c/c rwd sb
What is the easiest way to tell if your lift pump ( HFCM) has took a dump?
Pulled the secondary filter cover on top n there is no fuel there and I don't hear the pump wizzing as usual! Do I need to hole the filter down while some else turns the key or is there something else I need to do ?
wildchild200 is offline
post #2 of 2 Old 05-01-2013, 05:44 AM
The pump should run for several seconds when you turn the key to on. If there is no fuel in bowl, you have a problem (there is no special trick to the test).
You said you cannot hear the pump run. Frst thing to check would be the fuse, and then check for power at the connector.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
