Fan constantly running - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-29-2013, 06:01 PM Thread Starter
04 6.0, My fan constantly runs and sounds like a windmill running down the road and killing my fuel mileage and power. I have just replaced the bad egr cooler with a delete kit, oil cooler, water pump and fan clutch. THe only thing i havent replaced is the thermostat. After fixing all the stuff the fan still comes on while driving through town and is running around normal operating temperature. What is the next thing to do or replace? THermostat? I have talked to the ford garage and they do not know. There is no water loss and i am not loosing any out of the resevoir. Any help would be greatly appreciated
6.0 leaker is offline
post #2 of 4 Old 04-29-2013, 07:21 PM
what is your coolant temperature?
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #3 of 4 Old 04-29-2013, 09:02 PM Thread Starter
It's running 195 to 200
post #4 of 4 Old 04-30-2013, 05:37 AM
Does the fan run at high speed all the time? based on the work you have done, I assume you have had the truck for a while. Since you replaced the fan clutch, the flirst place I would look is the wiring to the clutch to see if something is shorted (or open) - I am not sure how the system works (i.e. signal high to run fan or connection to ground to run fan).
Also, what is your EOT? that can also be used to command the fan high (i think).
MikeB
PSDMikeB is offline
Tags
clutch , fan , hot , thermostat
