Weak Alternator?? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-29-2013, 05:06 PM Thread Starter
Weak Alternator??
I picture is worth a thousand words. Is this something to worry about? Is this indicating battery or alternator issues. Note RPM's, I would think this would be higher.
ID:	104289   Click image for larger version
Dom350 is offline
post #2 of 7 Old 04-29-2013, 07:23 PM
Looks low to me. Assuming your glow plugs had shut off, if this is the normal voltage all the time you are at risk of Killing your FICM.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #3 of 7 Old 04-29-2013, 07:29 PM
ZMANN's Avatar
Quoted: 1570 Post(s)
I'd get the batts individually tested and the alt tested
I may also throw a meter on the Alt lead at the back of the Alt
to see if it's higher
We Miss you Ronnie
ZMANN is online now
post #4 of 7 Old 04-29-2013, 07:31 PM Thread Starter
Great! I just put a new FICM in. Looks like a new alternator and batteries are in my near future. Only two years out of this battery set.... Even if the batts were bad, wouldnt the voltage be higher if the alternator was strong?
Dom350 is offline
post #5 of 7 Old 04-29-2013, 07:32 PM Thread Starter
Zman just answered my question, thanks! I will do that. But I've always "Read" that the batts should be replaced in pairs.....
Dom350 is offline
post #6 of 7 Old 04-29-2013, 07:36 PM
ZMANN's Avatar
they should be replaced in pairs ( so they have the same voltage and one doesn't drain into the other )
most places won't warranty both if 1 is still good so I buy the second and use the old good one in something else
your batteries may be fine but your charge looks low
the bummer is it may still test good
We Miss you Ronnie
ZMANN is online now
post #7 of 7 Old 04-30-2013, 02:43 AM
Snake's Avatar
Quoted: 46 Post(s)
Time to test the batteries and alternator.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
