6.0 leaking a little bit of oil and coolant? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-29-2013, 09:06 AM Thread Starter
'03whistler's Avatar
I just noticed a small oil leak under the back of the engine. It doesn't look like an engine seal but more like coming from the top of the motor. And it's not very much oil it's barely showing on the dipstick that it even leaks. I also noticed I lose some coolant and it seems damp around the overflow cap. I replaced it with an aftermarket overflow cap from O'Reily's but haven't driven it much since that. Could there be something major wrong?
'03whistler is offline
post #2 of 7 Old 05-03-2013, 08:43 AM
emdog's Avatar
Subscribed... having similiar prob myself.
emdog is offline
post #3 of 7 Old 05-03-2013, 09:04 AM Thread Starter
I haven't had any purging or anything from the degas bottle. I was told it may be some sort of sensor making the oil leak.
2003 F350 Lariat Crew Cab Long Box
Sonic Blue
33" Toyo MTs, Zoodad, AFE CAI, 4" straight pipe 5" tip
post #4 of 7 Old 05-03-2013, 09:08 AM Thread Starter
ICP sensor is what I was told. Have not yet had it replaced.
Sonic Blue
post #5 of 7 Old 05-03-2013, 09:16 AM
jtaylor75's Avatar
its a diesel, get use to small oil leaks. you'll drive yourself crazy trying to find small leaks. As far as the coolant be sure the cap is good. The full mark when cold should be the min mark. The new min mark is 1/2 inch below that.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #6 of 7 Old 05-03-2013, 01:02 PM Thread Starter
It hasn't affected performance or made any difference on the dipstick.
Sonic Blue
post #7 of 7 Old 05-03-2013, 01:12 PM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
It won't cause it's a small oil leak, I'd still replace the icp sensor just to make sure.. If its not that then try not to worry about it
Sent from AutoGuide.com App
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
