Swapped oil cooler now it misses? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-28-2013, 02:48 PM Thread Starter
gotta_gofast's Avatar
Quoted: 60 Post(s)
This weekend I swapped my oil cooler and installed a wicked wheel. Upon driving I felt the truck shake more than it did and feels like it is missing. The boost needle is a bit sparatic and shaky as it builds boost under mild acceleration (haven't pushed it further). There are no codes that I can read and no CEL. I listened around the exhaust (particularly the up pipe-turbo flange) and did not hear any hissing. The truck ran fantastic beforehand. My uneducated guess would be injector related? Could it be as simple as a connector not fully snapped in? What could I have done? Thanks!
2006 with your basic egr delete 4 inch exhaust, intake, tuner, and now the wheel.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #2 of 7 Old 04-28-2013, 02:51 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 897 Post(s)
Feedback Score: 6 reviews
Maybe double check the connections at the FICM.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 7 Old 04-28-2013, 03:03 PM Thread Starter
Quoted: 60 Post(s)
Update.... started it up to double check for any leak and this time it has a CEL. SCT tuner says P0264. I did the job without touching the FICM or its connectors but I'll play with it anyway.
post #4 of 7 Old 04-28-2013, 03:28 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
Any time I remove the intake manifold I take the FICM harness all the way out. It's too easy to damage an injector connector and not know it
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 7 Old 04-28-2013, 03:33 PM Thread Starter
Quoted: 60 Post(s)
I just hopped on here to tell all that I found the plastic "clip" part that retains the injector connector was missing. I assume its my fault. Pins are straight and the connector slides in and seats all the way down under pressure but without the retaining clips it backs out quite easily.
SO.... anyone have ideas how to go about this? I know the correct way is to either find a new male connector but for now I have to come up with something. I would like to make it removable for later (no packing it with glue!) so I figured I would secure it with a few well placed zip ties?
post #6 of 7 Old 04-28-2013, 06:23 PM Thread Starter
Quoted: 60 Post(s)
Runs great for now. I made a bracket that mounts on a nearby stud with two ears that push down on the connector base. Its a redneck fix but it'll work for now.
I can't wait to tell my wife why one electrical connector is going to cost $1400 bucks (or however much a set of 155 injectors are going for these days )
post #7 of 7 Old 04-28-2013, 08:04 PM
rogerallen33's Avatar
if your truck is missing it more than likely is a injector issue somewhere along the line whether it be on the electric or mechanical side don't know,,, worse case it is a compression issue, and yes check the connectors you might have broke one,, i bet would almost bet money it's a broking connector or wire somewhere, an injector misfire is like a spark plug misfire in a gasser, and the shake your talking about happens with a bad injector, this should give you a contribution code, you need to have it scanned then you will know where to look,,,, and it's not good driving one for too long missing like that ,,,,, a bad injector drove on for 2 long can melt a piston and ring fix it asap
rogerallen33 is offline
