Thinking its time for an oil cooler - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-28-2013, 07:10 AM Thread Starter
6.0kansaspowerstroke's Avatar
Unhappy Thinking its time for an oil cooler
I think its time to change my oil cooler. Lately i have noticed my temps are getting higher and higher. Last night coming home from the sand dunes pulling a 15 foot trailer with my rzr on it. My oil temp was 215 and coolant was 192. it was about 50 degrees and on flat ground with no wind. I can hit a 15 -20 degree delta empty going down the highway at 70. It doesnt stay very long but it still worries me that the cooler is going out. I lost the egr cooler somewhere a long time ago so i can rule that out. I also just installed a coolant filter.
Do you guys thinks it would be wise to go ahead and replace the cooler and flush and fill back up with elc coolant? Who has the best cooler out there? I wish i had the funds for the bulletproof kit but thats out of the question.
04 f-250 crew cab xlt
5 inch turbo back
zoodad mod
foil delete
egr? what egr? O that thing i threw it in the recycling bin. See im still green
full bumper replacement
head studs coming soon
ride rite bags and flip over ball
hankook mt's 285's
SCT X3
custom tuned by innovative
edge insight cs
sinister coolant filter
blue spring mod
6.0kansaspowerstroke is offline
post #2 of 11 Old 04-28-2013, 07:57 AM
Flush with chemicals before you swap oil coolers or else you will clog the new cooler. Follow the guide posted in the 6.0 tech section. It answers alot of flushing questions.
mfdengineer is offline
post #3 of 11 Old 05-02-2013, 02:09 PM Thread Starter
Who has the best oil cooler out there? what else should i do while im in there? Im hoping it will hold on till my next oil change cause i just changed it
5 inch turbo back
zoodad mod
foil delete
hankook mt's 285's
SCT X3
edge insight cs
blue spring mod
post #4 of 11 Old 05-02-2013, 02:26 PM Thread Starter
I found one on rock auto made by Dorman for 134 bucks. Would you guys trust it?
5 inch turbo back
zoodad mod
foil delete
hankook mt's 285's
SCT X3
edge insight cs
blue spring mod
post #5 of 11 Old 05-02-2013, 05:57 PM
Dorman tends to be cheap, Chinese stuff. I'd probably not go that route because getting to the cooler looks to be a PITA.
berusch is offline
post #6 of 11 Old 05-02-2013, 08:23 PM
JustinOOO9's Avatar
Quoted: 522 Post(s)
Garage
dont go with oem cooler I had headstuds, full delete and new oil cooler installed 3 weeks ago and I did a vc-9 flush for about an hr. then ran water for 3 days and drained and replaced with distilled water and did the headwork and some crap was still left in there now im seeing 9 delta just cruising.
do the bpd oil cooler kit if you can afford.
Im saving for it now because my 2nd oil cooler is showing signs but still within spec.
192 ect and 201 eot crusing 65 on highway....
click on my name and find the thread with "Nighmare in the heading"
Truck nightmare or am i just to being dumb?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #7 of 11 Old 05-03-2013, 12:28 PM
Quoted: 3 Post(s)
OEM Oil cooler is what I'd do if Bulletproof is too much.
Before changing it flush with restore and restore plus (follow instructions as advised above) and then run coolant filter for several hundred miles, changing out your filter at least twice (three times is better) to get the crap out of your system. The left over crap is what clogs the oil cooler. Once you have the new cooler run CAT EC-1 rated coolant and you shouldn't have more problems.
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
post #8 of 11 Old 05-06-2013, 03:45 PM Thread Starter
An update on my problem. Added a little coolant to the degas tank the other day. Come to find out my sinister coolant filter is leaking around the crrimped fitting that gouse to the de gas tank. Anyway i decided to take it out for a spin. Got her up to normal operating temp and let her loose. 7 miles at 110 mph. Yes you read that right 7 miles at 110 mph! That is one reason I love living in western kansas. I figured she is going to blow or hold strong. MY temps never got more than 7 degrees apart. So do you guys think my extreme temp differences were a fluke or should i still be worried?
5 inch turbo back
zoodad mod
foil delete
hankook mt's 285's
SCT X3
edge insight cs
blue spring mod
post #9 of 11 Old 05-06-2013, 09:38 PM
JustinOOO9's Avatar
Quoted: 522 Post(s)
Garage
you need to find a good tll hill (in Kansas?) and crank ac on hi and floor it up in 3rd gear and see what she says but 7 degrees sounds good man. your coolant temp could of risen because of leak.
Justin,
post #10 of 11 Old 06-02-2013, 09:41 AM Thread Starter
Update. My temps now get and stay around the 13-17 degree difference. Parts i need to do this change. List anything i miss. Oil cooler, intake gaskets, coolant, Do i have to run cat elc or will another brand of elc be ok?, flush chemicals, beer, turbo install kit, more beer, anything else?
5 inch turbo back
zoodad mod
foil delete
hankook mt's 285's
SCT X3
edge insight cs
blue spring mod
