how did you fix your knocking issue? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-27-2013, 09:51 PM Thread Starter
i have a knocking noise at idle, its not crazy loud but its noticeable at least to me, no loss of power and truck is running great, i have used the search and found many others that have had this problem but nobody ever post what they did to fix this issue (wrist pin, injector, main bearings, valves) are all ideas i have, so if you have had this problem please let me know what it was, no codes, passed buzz test, passed contribution rest
craigisgod is offline
post #2 of 4 Old 04-27-2013, 10:13 PM
JustinOOO9's Avatar
Quoted: 522 Post(s)
Garage
engine knock or injector miss?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 4 Old 04-28-2013, 05:18 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
Depending on the tune you use, you will see a big difference in knock. The more advanced the SOI, the louder the knock. Typically the colder the temp at start, the louder it will be. Partially due to most tunes advancing the SOI until close to operating temp.
Now if nothing has changed, you might want a second opinion with a long in the tooth diesel operator. Usually a problem will be heard as a metallic tick.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 4 Old 04-29-2013, 05:01 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
I've seen injecors that work properly but seem to rattle at idle.
AshevilleEngine.com is offline
