Another 6.0 No Start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-27-2013, 03:53 PM Thread Starter
Z00KA's Avatar
Send a message via Yahoo to Z00KA
2004 F350 with only 54k miles...yup, just 54K! Anyway, over the last week, truck would start, but "diesel" (rough running), but would smooth out after a minute of idling, then everything was good (power, smooth, etc.). Drove it work a few day ago, and figured the start up problem was due to my egr "cokeing up" and ran it pretty hard for a about 20 minutes (accelerating up to 80 mph after dropping down to around 55, and back up again). Truck ran smooth, no chugging or coughing. Next day...same rough startup, then smooth to work. After work, cranking but almost starting with black smoke, but alas...no start and battery that needed replacement, cranked down pretty quickly. New batteries...no luck. Noticed fuel level was just above empty, so trucked in 5 gallons...crank but no luck.
Today, put a OBD2 scanner on it...no fault codes. Towed it home, oil change with Rotella T, new oil filter, new fuel filters (plenty of fuel in upper cup) but both filters pretty dirty. Pulled the EGR and it was "coked". Cleaned with carb cleaner and reinstalled. Cranked and it sounded like it really wanted to start, but wouldn't... didn't want to crank on it too long. Will put my battery charger on it over the new few days try again.
Now, my fault...even though the mileage was less than 5000 miles since my last oil change (Motorcraft) (she doesn't get driven much) it has been a little over a year since oil change (today)!!!
Any ideas would be greatly appreciated.
p.s. - so embarrassed to post about the neglect I've put her through
Joe
'04 F350 PSD Crew Cab 4X4
Z00KA is offline
post #2 of 5 Old 04-27-2013, 08:15 PM
blackhawk783's Avatar
Mine did something similar. It was the HPOP.
Steve
blackhawk783 is offline
post #3 of 5 Old 04-28-2013, 06:05 AM Thread Starter
Z00KA's Avatar
Sorry for my ignorance...HPOP?
Joe
Z00KA is offline
post #4 of 5 Old 04-28-2013, 07:27 AM
HPOP = high pressure oil pump
You show all the classic signs of no low oil pressure in the high pressure side! So that is usually caused by a crapped out HPOP or bad o-rings on the stand pipes or dummy plugs. Pumps cost around $600 depends where you get them or if you really plan on keeping the truck get that billet pump made to solve all the 03-04 pump problems think they are closer to $1000 though.
You need to do an air check to see if it is the o-rings or pump to narrow it down or just bite the bullet n just do all of it so you don't have to sweat it anymore
wildchild200 is offline
post #5 of 5 Old 04-28-2013, 10:24 AM
I'm also experiecing the same problem truck started up fine, just took a while to fire up, then when I got off work the engine keeps cranking and no start, my oil pressure gauge didn't move an inch. Check for codes nothing came up had the truck towed back home, and laid on the starter with my foot on the gas pedal it started right up could the ficm be the problem or the hpop ? Sorry Zooka for the thread jack.
2006 F-250 6.0L Powerstroke, K&N intake with S&B filter, 3.5" - 5inch Mbrp Cat back exhaust with muffler delete pipe, Garret Powermax, Performance Machine Coolant filter, SCT Livewire w/Innovative Diesel Xtreme tune, High idle mod, Glowshift gauges Egt, oil temp, fuel pressure. 2.5" leveling kit, 35X12.50R17 Nitto Trail Grappler, Rancho Dual Steering Stabilizer, Rancho 9000XL Shocks.
doombugie is offline
