It has been discussed..... - Ford Powerstroke Diesel Forum
post #1 of 27 Old 04-27-2013, 06:53 AM Thread Starter
strokevin's Avatar
Alright, so I know this has been discussed many times, but I am having some trouble finding any posts with my particular symptoms. I have some readings for you guys to look at after I explain the problem. I have an Edge CTS on the truck so the readings were taken from there. If there are any other readings you need, or a better way to take the readings other than the CTS, please let me know with specific instructions or specific PID's on the CTS.
Two days ago after work, I start the truck up and it starts just fine. I let it warm up to about 120 then head down the road. I have no power. Turbo is boosting but it is gutless. I got home and let it sit over night. Got in yesterday morning and had the same issue. Started right up, but no power whatsoever. I checked the codes and had none. I tried standing on the throttle to see if something would happen. Truck sluggishly downshifted but again with no power. RPM's went to 3100 and held there so I let out of it. Checked the codes again and had a P2290 (ICP Voltage Too Low). So I shut the truck off and tried starting it up again (truck is at operating temps) and it just cranks. After about 10 long cranks (6-8 seconds) the truck fires. After the truck started, I cleared the codes again and tried driving it. Threw no codes until I hammered the throttle. It seems that I only get the code when on heavy throttle. Any ideas?
Readings I took were:
ICP Voltage:
KOEO 0.2V
Cold Cranking 2.3-2.5V
Idle Cold 1.3V
FICM Voltage is always between 48 and 49.5V
Truck is a 2004 with 120,xxx miles. Only mods are in the sig below. I returned the truck to stock settings also. Like I said, please let me know if you need more info, and specifically what info. Thanks for all your help.
Kevin
2004 F-250 6.0L
119,xxx miles when I picked her up
5" Diamond Eye Turbo Back
S&B CAI
Sinister Diesel Intake Elbow
Sinister Diesel EGR Delete
Sinister Diesel Coolant Filter
Blue Spring Upgrade
Edge CTS w/ EGT
SCT 3015
6" lift running 37x13.50R18 Toyo M/T's
strokevin is offline
post #2 of 27 Old 04-27-2013, 03:30 PM Thread Starter
strokevin's Avatar
No one has anything to say????
Sent from AutoGuide.com App
2004 F-250 6.0L
S&B CAI
Blue Spring Upgrade
Edge CTS w/ EGT
SCT 3015
post #3 of 27 Old 04-27-2013, 04:16 PM
what is your reading when you hit the pedal driving sounds like you have a high pressure oil leak. Is your Icp reading maintained while driving . Does your IPR increases and ICP lower that sort of stuff will tell if you have a leak.
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #4 of 27 Old 04-27-2013, 05:09 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
I agree sounds like a high pressure oil leak. Definitely something to do with oil pressure or fuel pressure.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #5 of 27 Old 04-27-2013, 06:44 PM Thread Starter
strokevin's Avatar
How do I test the IPR? I was watching the ICP while driving yesterday and it did go up when I hit the pedal. I want to say like 1.8V but I will have to confirm that tomorrow.
2004 F-250 6.0L
S&B CAI
Blue Spring Upgrade
Edge CTS w/ EGT
SCT 3015
post #6 of 27 Old 04-28-2013, 09:29 AM Thread Starter
strokevin's Avatar
Alright. So I went for a drive just now. Truck started up just fine, like it does when it's cold. ICP Volts before start were 0.2V. While cranking went to ~2.4V. After it started and a cold idle, ~1.1 to 1.2V. Let it warm up and went for a drive monitoring the ICP Voltage via my CTS. The voltage would climb when I pushed on the accelerator to about 2.0 volts while holding steady at half throttle. When I pushed it to the floor the voltage would go up to about 2.6V and then drop off to around 1.1V and stay around there until I let out of the throttle. When I let out, it would go back up to 2.8 for a brief second and then drop back to around 1.1V as I let it idle back down. I took some shots of my CTS at cold idle and then at hot idle when I returned home. Hopefully this will get me some answers or at least a starting point from someone on here. Really hate having my truck down. Thanks everyone.
[URL=http://s1304.photobucket.com/user/kevinseipp/media/1657CCB9-07E1-4DE3-995F-A124D918A582-576-0000004DB15E9CD2_zpsbb6cc843.jpg.html][URL]
2004 F-250 6.0L
S&B CAI
Blue Spring Upgrade
Edge CTS w/ EGT
SCT 3015
post #7 of 27 Old 04-28-2013, 09:39 AM Thread Starter
strokevin's Avatar
I just went back out and tried a hot start on the truck. It started, although it did take a little bit longer than normal (maybe 2 seconds cranking). I wanted to check the ICP Voltage at hot idle again. It is more like 0.9V rather than the 1.0V the picture shows or that I stated above. I also did a 4000 RPM runup and it didn't get choppy anywhere or lose ICP Voltage. The ICP V went up to about 2.4V and held steady while the ruck was at ~3800 RPM.
2004 F-250 6.0L
S&B CAI
Blue Spring Upgrade
Edge CTS w/ EGT
SCT 3015
post #8 of 27 Old 04-28-2013, 10:11 AM
Snake's Avatar
Quoted: 47 Post(s)
Read pressure instead of voltage.
I agree it sounds like a high pressure oil issue.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #9 of 27 Old 04-28-2013, 11:55 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
If your truck is not under load the ICP will not get very high. You need to compare the ICP for the IPR value commanded. More than likely the ICP low is coding because the IPR is commanded near closed, but the ICP is not reaching the target value. There is no doubt you have a HPO issue, but now you need to figure out if it is IPR, pump or seal related.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #10 of 27 Old 04-28-2013, 02:58 PM Thread Starter
strokevin's Avatar
This is the kind of informaiton I was looking for. Thank you. I will report back with my findings. Any suggested starting point? Leak test?
2004 F-250 6.0L
S&B CAI
Blue Spring Upgrade
Edge CTS w/ EGT
SCT 3015
