Who test injectors in Canada? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-26-2013, 01:50 PM Thread Starter
Does anyone know where in Canada one could send a set of 6.0 Powerstroke injectors to get tested? Or should I even bother wasting my time and just get an entire set (too bad I'm poor and can only afford one side at a time, FML).
My truck has been running pretty good up until a couple weeks ago when it started blowing blue smoke out of the blue (only from a stop and while idling, though) and ran like it was getting punched in the throat. So I pulled the plumbing off and I had oil dripping out of the hot and cold side pipes and intercooler. I also pulled my injectors and one of them was bone dry and caked with a ridiculously unnecessary amount of carbon. Two of them had this gel-like substance on the injector housing while almost all the others had black tips with carbon build-up.
E-NA6CE is offline
post #2 of 2 Old 04-26-2013, 04:20 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Your problem sounds like a turbo ring seal.
The injectors may need a good cleaning or even some repair. Chatham in Ontario is the only one to flow and repair 6.0l injectors. I didn't find anyone else. $30 each plus shipping and taxes to flow them. I used them to hone my nozzles. They will also upgrade injectors, but they typically use port plugs.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
