Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 02-17-2008, 06:24 PM
jiggs jiggs is offline
turbo ?
With the bucking of the engine If it is the turbo will it reset and run fine for a while after the key is turned off and then restarted the motor. check engine light is on till you restart the engine.
Old 02-17-2008, 06:34 PM
mako314 mako314 is offline
sounds like a classic cps failure to me with the engine bucking.
Old 02-18-2008, 01:57 AM
npccpartsman npccpartsman is offline
The best thing to do is get it diagnosed. It might be the turbo veins sticking or the EGR. CPS very RARELY fails on the 6.0. One of the bigger automart chains can probably scan it for you.
Old 02-18-2008, 05:27 PM
I didn't mention on this post the 6.0 is in a F-650. The dealer were this was bought said they did not have the right cable to scan for the trouble The cable is very expensive and they are not going to buy it. I don't know but if it is pricey will an auto parts store have that kind of cable ?
Thanks for any help
Old 02-18-2008, 05:28 PM
Marty Marty is offline
International Threat
F650... Are you sure it's a 6.0...
I know there were Cat 300 and Cummins 5.9 options.
Old 02-19-2008, 07:23 PM
Yes I am sure it is a 6.0 The year is 06 but it could of been built in 05.
Old 02-19-2008, 08:13 PM
mschn99 mschn99 is offline
the 650 was available with a 6.0......most had cat or cummins motors but it is available...
definately sounds like a sticking turbo or stuck EGR valve issue...but without the code its tough to be sure...
Old 02-20-2008, 04:34 PM
I unplugged the egr valve and it still bucked . It does feel like the turbo sticking just because it runs like something is turning off then on.off.on Ether it is getting worse or it's the cold weather. Today the light came on just idling and it happened 3 more times in 2 miles. After it warmed up it wasn't as bad but on a 150 mile trip the light came on at least 10 more times and lost the turbo boost every time
