EOT guage turns off, then no start - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-24-2013, 08:00 AM Thread Starter
dxusmc's Avatar
Not EOT, actually EOP. Guess I should pay attention to those dummy gages a bit more even with a tuner. Truck still runs fine when driving, but now realizing what it means (hit me like a sack of bricks on how stupid I feel) I'm not sure I want to be driving it until I figure out if its just a sensor or in face my low pressure oil system is on the fritz. Any good testing procedures before I break open the haynes manual?
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #2 of 12 Old 04-24-2013, 09:02 PM
The EOP sensor is essentially an on/off switch. If it is low, engine shuts down to protect itself. Simple enough to change it out and inspect the wiring. Either that or put on a gauge to see if you ahve a low pressure oil problem.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #3 of 12 Old 04-25-2013, 07:42 AM Thread Starter
dxusmc's Avatar
have actually put a manual gauge to it yet, but my canister fills up cranking with no filter when I push down the tab...so my low pressure works. Read somewhere else on the org that if the IPR valve gets stuck open it will cause the high pressure system to read low and sometimes make the low side read low..that or it could be as simple as the sensor/wiring going bad like you said. Unfortunately Ive been having FICM issues so if I had a leak on the high side before this, I didn't know and just chalked it up with that crappy board I have sitting on my driver side valve cover
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #4 of 12 Old 04-25-2013, 08:20 PM
I re-read your first post. Are you getting EOT and the low pressure oil system confused? If the dummy gauge drops to 0, that is pressure not oil temperature. Your tuner is shoing you oil temperature not pressure.
on your insight, watch the ICP pressure and see if it stays low when you would expect it to go up (i.e. giving it throttle). That would likely tell you if you have a sticky IPR.
Otherwise you will need autoenginuity or IDS to command the valve directly and see if the ICP changes with IPR commands. If it is intermittent, you may never get it to fail when you are testing it. May just want to get a new oil pressure switch to see if that is the intermittent issue. I think they are pretty cheap.
MikeB
PSDMikeB is offline
post #5 of 12 Old 04-26-2013, 07:54 AM Thread Starter
dxusmc's Avatar
yea, initially I said EOT when I meant EOP. I had it out yesterday since I knew it was getting oil...just not reading. I noticed when I was WOT dummy gauge worked fine and the engine sounded good. As soon as I back out of it and my ICP got to about 580s-590, the gauge went to 0 again. Even WOT I was only seeing 1400-1500..thought it would be more than that. I'm definitely trying to find a good scanner for it so I know whats going on.
Also just updated my insight yesterday to add that PID along with others and starting tracking exhaust back pressure. 0 reading at all times. Truck just keeps throwing me curve balls
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #6 of 12 Old 04-27-2013, 02:30 PM Thread Starter
dxusmc's Avatar
Started tearing the beast apart today since I'm scared to drive it. Found oil lining my intake. Traced back to quite a bit of oil coming out of the compression housing on my turbo..and some coming from the CCV, but not nearly as much. I find it a bit strange that I was getting good boost...but is my turbo fried? or maybe just have to take it apart and fix something internally...Any ideas? What am I looking at here
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #7 of 12 Old 04-27-2013, 03:08 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
The oil you see is like a bloody nose. It usually looks worse than it is. It normal to see oil at all the low spots in the CAC tubing and intake. As long as you are not seeing blue smoke or noticeable loss of oil, it is probably fine.
You probably need to just replace the oil pressure switch or check the wiring.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #8 of 12 Old 04-27-2013, 03:12 PM
Quoted: 43 Post(s)
If you have a tune on it, it is normal to see a fake ICP of 1500-1600psi when it is really in the mid 3000s. The only way to tell is to put on a stock tune or use the true ICP voltage.
Frank
Working for Toys
post #9 of 12 Old 04-28-2013, 09:59 AM
I forgot to mention... Make sure you are using a OEM oil filter and cap.
MikeB
PSDMikeB is offline
post #10 of 12 Old 04-28-2013, 08:06 PM Thread Starter
dxusmc's Avatar
Yea, I've been using motorcraft filters since I've owned the truck. Have been tearing it apart little by little everyday. Living in NY, I have some major corrosion and rust problems..every bolt is a chore. But its coming along.
Marines 2004-2009
Army 2009-2013
dxusmc is offline
