Need ford HD mechanics help with potential blown gasket diagnosis - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-23-2013, 07:33 PM Thread Starter
Steve6L's Avatar
So ever since i have bought my truck I have been debating wether or not my head gaskets have blow or not... Plot thickens
Pukes all the time, thought it was egr as it was soaked, so I deleted the cooler and valve.
Thought it could be the cap, changed it for a new one and it still pukes(heard that it could be a bottle problem as well and bottle and cap should be replaced together who knew!)
Only thing I have read about left that could cause it to puke is the oil cooler flash boiling coolant cause its clogged, however my deltas are pretty constant at 2-4degrees and saw a max of 10 degrees when towing a 5000 pound trailer but that was only a second or two until the oil cooler started doing its thing.
Can anything else cause the coolant to puke? Is there something I'm missing?
Anyways I decided last oil change to keep some oil and get an oil analysis done, and hey while I was at the oil place might as well drop off some coolant as well. I have now recieved the $80 for both samples analysis back and yea there's a lot of numbers, and I don't have a clue what I'm looking at.
Are there any 'nice' 'awesome' 'sweet' 'beauty' ford mechs out there I can send the reports too and give me your expert opinion if I need to change my gaskets or if they are fine and something else is causing my puking problems.
Please help !!!! it might stop snowing up here in Canada soon and I want to run my looney wild once it drys up.
A dedicated 6.0 driver that desperately needs help. Steve6L.
Sent from AutoGuide.com App
2004 CCSB King Ranch-Studded-HG are one way out again-4 inch mbrp-4 foglight mod-8000k hid in all lights-Edge Insight CTS-SCT SF3- Looney Wild/tow/fuel-Riff Raff Boots-Metal CAC Tubes-S&B CAI-CCV mod-07 Front Diff Swap-Rear Captain Chairs-ISSPRO Performax Gauges 3 and growing-2012 Tailgate/camera-2012 Rear View Mirror-Amp Power Steps-2012 Rear Bumper-20 Inch Stock Rims-Auto Enginuity-2012 Power mirrors
Steve6L is offline
post #2 of 13 Old 04-23-2013, 08:11 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Blown head gaskets. The oil cooler will not flash boil the coolant.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 13 Old 04-23-2013, 08:18 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1782 Post(s)
100% agree with tuscany here. Based on the parts replaced and the symptoms you are in for some head work.
Originally Posted by Heavy_GD View Post
Merged, because lamp.
toren302 is offline
post #4 of 13 Old 04-23-2013, 09:47 PM Thread Starter
Steve6L's Avatar
Oh in case its not in my sig:
Studded with oem parts done properly
-which makes believing gaskets are gone far fetched.
Any HD mechs out there that can look at these oil analysis for me? As being very familiar with gaskets if there is a leak in either or both of them, materials off the gaskets will 100% be in either my coolant or oil or both. Hence the pricey tests. Which I have no idea how to read or make sense of.
Steve6L is offline
post #5 of 13 Old 04-24-2013, 05:08 AM
most oil reports are simply looking at wear metals, contaminant metals, and oil quality (i.e. acid or base number, oxidation, etc...). I am not sure you are going to see definitive data to tell you that you have blown HGs.
Rig up a pressure gauge to the coolant system, that will tell you for sure. Also, you can buy a coolant tester that detects carbon monoxide in the coolant. Since you have a deleted EGR cooler, that will also confirm blown HGs.
MB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #6 of 13 Old 04-24-2013, 05:14 AM Thread Starter
Steve6L's Avatar
Oh snap, I forgot to mention that, a buddy of mine had one of those coolant testers and confirmed it worked when he had previously used it to diagnose blown gaskets. He said color changed in the fluid in about 20 seconds. I left my truck running for 20 mins (kit recommends 2 I think) nothing, no change... Hahah nice dilemma eh all signs point to gaskets all tests say no
Steve6L is offline
post #7 of 13 Old 04-24-2013, 05:16 AM Thread Starter
Steve6L's Avatar
Ill buy a mech pressure gauge when I'm home I guess, t it into the degas bottle line. I have heard guys saying 11 psi is normal operating psi, however I thought the cap was 4 psi?!!
Steve6L is offline
post #8 of 13 Old 04-24-2013, 05:24 AM
normal expansion of the coolant will get up to 8 or 10 psi typically. The cap is rated at 16psi. Once you have the gauge on and punch it, you will know.... the pressure will spike abruptly. Look for a youtube video of bad headgaskets/pressure gauge and you will see how fast it goes up.
MikeB
PSDMikeB is offline
post #9 of 13 Old 04-24-2013, 05:52 AM Thread Starter
Steve6L's Avatar
Makes sense that an instant pressure increase would take place as soon as throttle is touched if gaskets or heads are leaking
Steve6L is offline
post #10 of 13 Old 05-16-2013, 04:29 PM Thread Starter
Steve6L's Avatar
Took a little video for you guys while I was at work.finally got a pressure gauge. let me know what you all think.
Ps don't mind my buddy he has adhd
https://www.youtube.com/watch?v=LVyU...e_gdata_player
Steve6L is offline
