oil were it shouldent be - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-23-2013, 04:55 PM Thread Starter
i have what ive been told is blowby and apparently its bad. i have oil coming up through my dipstick and getting all over everything close by and even the under side of the hood. what do you guys think? gonna run the "ids" and a manuel compression check on it tomorrow and go from there. i just did a complete rebuild this is the last thing i need right now!
jherbie28 is offline
post #2 of 12 Old 04-23-2013, 05:08 PM
justinlogue5_0's Avatar
Just throwing this out there but check your CCV for clogs,crimps etc...Could be putting to much back pressure on the motor.
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #3 of 12 Old 04-23-2013, 05:32 PM
Louiediesel's Avatar
maybe you should do the CCV mode ?
Louiediesel is offline
post #4 of 12 Old 04-24-2013, 02:49 AM Thread Starter
i do have a ccv mod and from what i can tell its not kinked or blocked but will double check.
post #5 of 12 Old 04-24-2013, 02:59 AM Thread Starter
after a better look it looks like it could be kinked at the top where the hose turns down.
post #6 of 12 Old 04-24-2013, 03:07 AM
Hope that fixes it for ya.
It never ends!
post #7 of 12 Old 04-24-2013, 03:20 AM Thread Starter
thanks man cuz the worst thing ive been told so far is "you need a motor" i guess ill clean it all up and see if it continues to blow oil. i was told not to do that ccv mod just for this reason, who knows
post #8 of 12 Old 04-24-2013, 04:04 AM
There's nothing wrong with doing the ccv mod but,you do have to use the right hose. I use a silcon based hose for mine. Strong enough to stand up to the elements but flexible enough not to get pinched shut. I did make a good size loop for safety sakes also. Let us know how it goes.
It never ends!
post #9 of 12 Old 04-24-2013, 05:03 AM
justinlogue,
where did you get the silicon hose?
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #10 of 12 Old 04-24-2013, 05:17 AM
I actually had gotten several feet couple years ago out of a parts house that was being auctioned off. It was something you would see on the heater hoses on a race car etc... I will look around and see if I can find a link to something like I have.
It never ends!
