I don't like the looks of this.. - Ford Powerstroke Diesel Forum
post #1 of 16 Old 04-23-2013, 02:49 PM Thread Starter
Boeing747's Avatar
sooo i bought my truck about 3 months ago and all was well. truck had 99k on it and already had egr delete, arp head studs, Black Onyx head gaskets, oil cooler, hypertech tuner and a few other things..
ever since i bought the truck the heat has been kind of odd.. it blows hot and then will go cold unless you rev it, speed up, or go up a hill.
coolant level was low so i filled it up to about where is should be. and that was that.
about a week later i checked the coolant again and it was very low. not even in the degas bottle. so i filled it up to just over the low when it was cold.
coolant has puked out the cap within 30 minutes of EASY driving since.
whats wrong with my truck? could it really be a headgasket issue even after it has been bulletproofed? can i continue to drive it like this??
i don't really have the money to pull the heads off anytime soon.
Thanks for the help!
F350 6.0 Powerstroke
Fully Bulletproofed (ARP Headstuds, EGR delete, oil cooler, ect...), Hypertech tuner, 4" MBRP Exhaust, K&N Intake, Fog Light Mod, Pioneer touchscreen stereo + aftermarket speakers, and BFG All-Terrains
Boeing747 is offline
post #2 of 16 Old 04-23-2013, 03:45 PM
Snake's Avatar
Quoted: 47 Post(s)
If the head stud install wasn't perfect, it's absolutely possible to have issues. Off the top of my head, I could see problems if the heads weren't magnafluxed and decked, if the block surface wasn't prepped correctly, and if the studs weren't torqued to the proper number or in the wrong sequence.
There's a very good chance that if all of the above were perfect you're still screwed. Black Onyx gaskets don't have a very good reputation.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #3 of 16 Old 04-23-2013, 03:47 PM
mattdoxa's Avatar
The black onyx gaskets are known to to fail. I would advise against driving untill you ateast have a way to monitor your temps. Ect and eot primaraly. Edge insight or a scanguage are theeasiest ways to go about doing that
06 king ranch dually. 4" silverline duals, sct x3 tuned by tony wildman.
arp studs rcd egr delete updated fpr 6.4 banjos warren 175/stock. stage 1 from mtw,
mattdoxa is offline
post #4 of 16 Old 04-23-2013, 03:56 PM
Like a boss!
Laferty's Avatar
This is exactly what I was experiencing. Kept adding coolant and switching to new coolant caps. Had to face facts and admit my heads were leaking.
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #5 of 16 Old 04-23-2013, 06:17 PM Thread Starter
Boeing747's Avatar
alright.. so its probably an issue with the head gaskets..? could it be caused from anything else? i mean i know it could very well be the head gaskets but.. i just feel like the chances of that have got to be extremely low considering they had gotten studded and replaced like 10k miles ago.
post #6 of 16 Old 04-23-2013, 07:31 PM
Sorry to say its definitely headgaskets my black onyx hg's lasted a month, then I used Oem.
Sanndnsurf is offline
post #7 of 16 Old 04-23-2013, 08:22 PM
Like a boss!
Laferty's Avatar
From my knowledge, it is the head gaskets for sure if you have the egr delete. Are you positive it is deleted? The cylinder pressure is being leaked into your coolant system causing the excess pressure. If you have the tools and space doing your heads wont be costly since you have everything else done already.
2006 CCLB
Laferty is offline
post #8 of 16 Old 04-24-2013, 02:53 AM
Snake's Avatar
Quoted: 47 Post(s)
You're in Stage 1: Denial.
After my head gaskets blew on the stock head bolts, I had the truck studded and used OEM gaskets. A friend used the same tech around that time as well. Both of us had blown head gaskets less than 10k miles later. My best guess is that the installs were not done correctly.
Google Black Onyx head gaskets and I'm willing to bet you progress to Stage 2: Acceptance.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #9 of 16 Old 04-24-2013, 04:54 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Probably your gaskets, The black onyx are known to fail even with arp studs...
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #10 of 16 Old 04-24-2013, 05:02 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
that sucks man atleast you can reuse the studs... be sure to get OEM gaskets this time.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
