Full Operating Temp - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-23-2013, 03:07 PM Thread Starter
Gushatman's Avatar
Full Operating Temp
I changed the oil in my truck yesterday, and now my full operating temp deltas are 162 ECT and 169 EOT...I used Rotella Synthetic 15-40 in it. Any clue as to what my issue is?
Gushatman is offline
post #2 of 7 Old 04-23-2013, 04:05 PM
Quoted: 3 Post(s)
Well you would need two faulty sensors, but I guess that's a possibility. Are temps close to outside temps after not running overnight?
Maybe your T-stat is stuck open and truck is never warming up?
2005 6.0 Lariat Crew Cab 4x4 Short Bed
SCT X3 Tuner, Looney Tune from Quick Tricks
Bulletproof EGR Cooler (I live in CA, smog mecca)
FICM with Atlas40 from FICMrepair.com
Updated Standpipes, Dummy Plugs and STC
4" Turbo Back Magnaflow Exhaust
DC Power 185 amp alternator and wiring upgrade
Blue Spring
Coolant Filter
CAT EC-1 Coolant
Dashboss Monitoring including pyro and fuel pressure
Zoodad Mod
fuzzman is offline
post #3 of 7 Old 04-23-2013, 04:20 PM Thread Starter
Gushatman's Avatar
Yes, temps are very close to outside temps, when sat overnight.
post #4 of 7 Old 04-23-2013, 04:25 PM
thumper280zx's Avatar
how long did you run the truck for. and usually when a thermostat get stuck open it still warms up to about 180*.
06 F350 King Ranch
egr delete, coolant filter, sct tuner more to come soon
thumper280zx is offline
post #5 of 7 Old 04-23-2013, 05:07 PM Thread Starter
Gushatman's Avatar
I ran it for 25 miles of low 4 lane driving.
post #6 of 7 Old 04-27-2013, 02:31 PM
I would say the thermostat is not operating correctly. When I bought my truck, I got 170 ECT readings at operating temp. I changed to a new Ford thermostat, and it went to 192. Now, 30,000 kms later, my regular ECT is 189.
I'm considering trying to get a 195 or 200 thermostat soon, to see if t will increase my MPG.
Check your top Rad hose during the warm up cycle. It should stay cool (realtively) until the thermostat opens, and then it would feel much warmer. If the therm is partly stuck open, then the hose would just warm up progressively with the engine.
Good luck.
2006 F250 ext cab, short box, 4x4 auto
ARP studs, BPD EGR cooler, Ford oil cooler, HPOP and turbo line updates (by Bernhausen @ 219K Kms)
BPD billet water pump, AFE CAC pipe
Eng. strategy VXCF9H7; TW Extreme tune
4" SS Magnaflow turbo back w/ muff & hi flow cat.
Edge CTS monitor w/ EGT
CAT EC-1 coolant w/ bypass filter
stock air intake w/ shielded Zoodad
3.73 axles, 275/70R18 BFG A/Ts
To do: injectors, Snow Stage 2 water injection, blue spring, fuel press sensor
metric convert
freecanadian is offline
post #7 of 7 Old 04-27-2013, 03:17 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
You problem is totally unrelated to your oil change. It seems your thermostat has decided it wants to be replaced.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
